Adding a custom block / einen eigenen Block hinzufügen
Re: Adding a custom block / einen eigenen Block hinzufügen
I´d add a left block according the first posting. Every thing is ok in style subsilver. But in style prosilver the backgroundcolor is lightblue #ECF1F3 instead of blue #CADCEB in the other left blocks. How can I change this?
Please provide a Link.
Theres a ton of possible reasons, so please help us with a Link
I used exact the code of the first posting.
Not exactly... but even though, the code is for B3P 1.0.2
Since you're using B3P 1.0.3, use this code for your Block:
{$LR_BLOCK_H_L} Headline{$LR_BLOCK_H_R}
Place your Code here
Thanks for the fast and qualified response. Now my block has the same style as the others, even using prosilver.
Made an updated KB Article for both German and English Language. View first two Posts for the Links...
@Yeti: there are new codes for subsilver2 also
- phpBB.com User: Tieno
Hello.
I have create a new bloc on my portal.
But i can't view this.
My custom block is liste_equipe_alliance.html:
I edit portal_body.html:
But nothing appears.
My forum is: http://www.forum-mugiwara-team.forumsfaciles.com
Can you help my please ?
{$C_BLOCK_H_L}<dl><dt>Liste des équipes</dt></dl>{$C_BLOCK_H_R}
<ul class="topiclist forums">
<li><dl>
<dd style="border-left: 0px">
<p>Voici la liste des équipes de l'alliance Akuma:<br />
-La Mugiwara_Team:Il s'agit d'une équipe très soudé,elle est composé d'une élite du village chikara.<br />
-Les brutes des sables<br />
-Ryuk Darkness Style<br />
-La Team-Kugan<br />
</p>
</dd>
</dl></li>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
<td valign="top">
<br style="clear:both" />
<!-- IF S_DISPLAY_GENERAL -->
<!-- INCLUDE portal/block/general_block.html -->
<!-- IF U_RESTORE_PERMISSIONS and S_DISPLAY_MAINMENU -->
<!-- IF S_DISPLAY_WELCOME -->
<!-- IF S_DISPLAY_WELCOME_GUEST and S_USER_LOGGED_IN -->
<!-- INCLUDE portal/block/welcome.html -->
<!-- IF S_CUSTOM_CENTER -->
<!-- INCLUDE portal/block/custom_center.html -->
<!-- IF S_LISTE_EQUIPE_ALLIANCE -->
<!-- INCLUDE portal/block/liste_equipe_alliance.html -->
Try updating to the newest version, that should probably help a lot.
I can't updating to the newest version because French support not support this newest version.
But i have find at this support a new answer for this.
Thanks
Thanks
<!-- IF S_LISTE_EQUIPE_ALLIANCE --> is not an valid switch... just include your Custom Block without such a Switch
hat jemand evtl einen Lösungsvorschlag um vom Classifieds modul z.b. die letzten 5 neuen Kleinanzeigen im Portal Anzeigen zu lassen?
mfg Basti
mfg Basti
- phpBB.de User: Bash
- phpBB.com User: Bash
Hello
I want to duplicate the 'news' block, creating a new block entitled 'results'. Everything would appear fairly straight forward even for a noob like me, except for a part in includes/acp_portal:
Would I add the 'results' string like this...
or...
or something else?
Also, do I need to add any additional SQL queries?
Thanks very much for your time
// Store selected forums
function store_selected_forums($key)
global $db, $cache;
// Get selected extensions
$values = request_var($key, array(0 => ''));
$news = implode(',', $values);
set_portal_config($key, $news);
global $db, $cache;
$results = implode(',', $values);
set_portal_config($key, $results, $news);
global $db, $cache;
$results, $news = implode(',', $values);
If you edit that function, I will cut your fingers off.
I guess you edited this part for your needs:
And I guess the exact part you want to modify is this:
You should change it to something like this:
A little bit further down you will have to find this line:
Replace it with this:
Now it is important to know what you changed this line to:
If you changed it to this:
Do this:
Find:
After Add:
Then the script will save the selected forum IDs.
I hope this helps.
case 'news':
$display_vars = array(
'title' => 'ACP_PORTAL_NEWS_SETTINGS',
'vars' => array(
'legend1' => 'ACP_PORTAL_NEWS_SETTINGS',
'portal_news' => array('lang' => 'PORTAL_NEWS', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_news_style' => array('lang' => 'PORTAL_NEWS_STYLE', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_show_all_news' => array('lang' => 'PORTAL_SHOW_ALL_NEWS', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_number_of_news' => array('lang' => 'PORTAL_NUMBER_OF_NEWS', 'validate' => 'int', 'type' => 'text:3:3', 'explain' => true),
'portal_news_length' => array('lang' => 'PORTAL_NEWS_LENGTH', 'validate' => 'int', 'type' => 'text:3:3', 'explain' => true),
'portal_news_forum' => array('lang' => 'PORTAL_NEWS_FORUM', 'validate' => 'string', 'type' => 'custom', 'explain' => true, 'method' => 'select_forums'),
'portal_news_exclude' => array('lang' => 'PORTAL_NEWS_EXCLUDE', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_news_show_last' => array('lang' => 'PORTAL_NEWS_SHOW_LAST', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_news_archive' => array('lang' => 'PORTAL_NEWS_ARCHIVE', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_news_permissions' => array('lang' => 'PORTAL_NEWS_PERMISSIONS', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
'portal_show_news_replies_views' => array('lang' => 'PORTAL_SHOW_REPLIES_VIEWS', 'validate' => 'bool', 'type' => 'radio:yes_no', 'explain' => true),
break;
'portal_results_forum' => array('lang' => 'PORTAL_RESULTS_FORUM', 'validate' => 'string', 'type' => 'custom', 'explain' => true, 'method' => 'select_forums'),
if ($config_name == 'portal_attachments_filetype' || $config_name == 'portal_news_forum' || $config_name == 'portal_global_announcements_forum' || $config_name == 'portal_recent_forum' || $config_name == 'portal_attachments_forum_ids' || $config_name == 'portal_poll_topic_id')
if ($config_name == 'portal_attachments_filetype' || $config_name == 'portal_news_forum' || $config_name == 'portal_global_announcements_forum' || $config_name == 'portal_recent_forum' || $config_name == 'portal_attachments_forum_ids' || $config_name == 'portal_poll_topic_id' || $config_name == 'portal_results_forum')
case 'news':
case 'results':
Find:
case 'polls':
$this->store_selected_forums('portal_poll_topic_id');
break;
case 'results':
$this->store_selected_forums('portal_results_forum');
break;
I hope this helps.
hehe
Well Marc, you'll probably laugh, but what I did was simply go through every file associated with the board3 mod (every file in the download package/root folder) and duplicate every instance of 'news' and rename it 'results'. I haven't actually changed anything (just added extra code) so I'm hoping I can just upload all these files and they'll be an extra news option in ACP but entitled 'results' (lol I can dream!).
*edit* oh and obviously I created new .html files (copied news html files and edited them). If you want I can post exactly everything I did, but it will take me some hours (as it did to create the edits xD).
