Style Version: 2.0.3
phpBB Version: 3.0.6
Board3Portal Version: 1.0.4
Style Download: http://www.stsoftware.biz/phpbb30_style.acidtech.html
Portal Demo: http://area51.mikevil.de/portal.php?style=87
 - This Guide is written for AcidTech, but it works for AcidTech Red, AcidTech Green and AcidTech Purple also. If you want to use this Guide for ..Red ..Green or ..Purple you just have to replace "AcidTech" with the Name of your Style in this Guide.
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/acidtech/template/portal/*.*
to: styles/acidtech/theme/images/portal/*.*
open: styles/acidtech/template/breadcrumbs.html
find:in-line find:Code: Select all
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>in-line add after:Code: Select all
<p class="breadcrumbs">Code: Select all
open: styles/acidtech/template/overall_header.html
find:add before:Code: Select all
<tr> <td class="navrow">find:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->add before:Code: Select all
<tr> <td id="contentrow">find:Code: Select all
<!-- ENDIF -->add after:Code: Select all
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) --> <div class="pm-notify-new"><div class="pm-notify-header">{L_INFORMATION}</div>{L_BOARD_DISABLED}</div> <!-- ENDIF -->find:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->add after:Code: Select all
<!-- INCLUDE breadcrumbs.html -->Code: Select all
open: styles/acidtech/template/portal/_block_config.html
_block_config.html for AcidTech
 - Diese Anleitung wurde für AcidTech geschrieben, funktioniert aber auch für AcidTech Red, AcidTech Green und AcidTech Purple.
Wenn ihr diese Anleitung für ..Red ..Green oder ..Purple nutzen wollt, müsst ihr einfach "AcidTech" in diese Anleitung mit dem Namen eures Styles ersetzen.
nach: styles/acidtech/template/portal/*.*
nach: styles/acidtech/theme/images/portal/*.*
öffne: styles/acidtech/template/breadcrumbs.html
finde:finde in dieser Zeile:Code: Select all
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>in dieser Zeile danach einfügen:Code: Select all
öffne: styles/acidtech/template/overall_header.html
finde:davor einfügen:Code: Select all
<tr> <td class="navrow">finde:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->davor einfügen:Code: Select all
<tr> <td id="contentrow">finde:Code: Select all
<!-- ENDIF -->danach einfügen:Code: Select all
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) --> <div class="pm-notify-new"><div class="pm-notify-header">{L_INFORMATION}</div>{L_BOARD_DISABLED}</div> <!-- ENDIF -->finde:Code: Select all
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->danach einfügen:Code: Select all
öffne: styles/acidtech/template/portal/_block_config.html
ersetze mit: (folge dem Link um zum Code zu gelangen)
_block_config.html für AcidTech
