AeroBlack
Spadewar
AeroBlack
Post by Spadewar »
i have done this to test out this style and i love it but one issue i am having if you go to my site
http://www.ironmog.org
you will see the forum information below the header area i cant seem to find that section and eliminate it from the front page. it is kinda tacky
Re: AeroBlack
I moved your question to a new Topic, since it has nothing to do with the config.
Please install your Style first: viewtopic.php?f=47&t=2978
Spadewar
Re: AeroBlack
Post by Spadewar »
style is installed been installed u can check it now
Re: AeroBlack
If you followed the install intructions you can disable the Header Menu in: ACP->Portal->phpBB menu:(Display the phpBB Header on the portal.)-> NO
If it is already "NO" and nothing happens, you must check all the edits described in the link above.
Return to “Styles Support”
