Link zu Deinem Forum: http://modoxmapping.mo.funpic.de/index.php
Portal installiert, bzw. es versucht.
Diverse Seiten durchsucht.
Bei diesem, auf Subsilver 2 basierenden Style findet sich folgende Zeile nicht:
Code:Select all
<div id="datebar">
Code:Select all
Shortversion on English:
Cant find the above postet line... where i have to fill something in?[/i]
Overall_Header.html
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
// copyright 1999 Idocs, Inc. http://www.idocs.com/tags/
// Distribute this script freely, but please keep this
// notice with the code.
var rollOverArr=new Array();
function setrollover(OverImgSrc,pageImageName)
if (! document.images)return;
if (pageImageName == null)
pageImageName = document.images[document.images.length-1].name;
rollOverArr[pageImageName]=new Object;
rollOverArr[pageImageName].overImg = new Image;
rollOverArr[pageImageName].overImg.src=OverImgSrc;
function rollover(pageImageName)
if (! rollOverArr[pageImageName])return;
if (! rollOverArr[pageImageName].outImg)
rollOverArr[pageImageName].outImg = new Image;
rollOverArr[pageImageName].outImg.src = document.images[pageImageName].src;
document.images[pageImageName].src=rollOverArr[pageImageName].overImg.src;
function rollout(pageImageName)
document.images[pageImageName].src=rollOverArr[pageImageName].outImg.src;
</script>
</head>
<a name="top"></a>
<div id="wrapheader">
<table id="bx" width="100%" border="0" cellpadding="0" cellspacing="0">
<td>
<table style="height:40;" width="100%" border="0" cellpadding="0" cellspacing="0">
<td><img src="{T_THEME_PATH}/images/header/h11.png" width="40" height="40" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h12.png" width="100" height="40" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/header/h13.png) repeat;" width="100%" height="40"></td>
<td><img src="{T_THEME_PATH}/images/header/h14.png" width="100" height="40" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h15.png" width="40" height="40" alt="" /></td>
<td>
<table style="height:140;" width="100%" border="0" cellpadding="0" cellspacing="0">
<td><img src="{T_THEME_PATH}/images/header/h21.png" width="40" height="140" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h22.png" width="100" height="140" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/header/h23.png) repeat;" width="100%" height="140">
<div id="logodesc">
<td><img src="{T_THEME_PATH}/images/header/h24.png" width="100" height="140" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h25.png" width="40" height="140" alt="" /></td>
<td>
<table width="100%" style="height=66;" border="0" cellpadding="0" cellspacing="0">
<td><img src="{T_THEME_PATH}/images/header/h31.png" width="40" height="66" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h32.png" width="100" height="66" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/header/h33.png);" width="20%" height="66" align="center">
<a href="{U_INDEX}"
onmouseover = "rollover('home')"
onmouseout = "rollout('home')"
<img src="{T_THEME_PATH}/images/buttons/home1.png"
name="home"
alt="Home Page" border="0"
height="40" width="101"
</a>
setrollover("{T_THEME_PATH}/images/buttons/home2.png");
</script>
<a href="{U_FAQ}"
onmouseover = "rollover('faq')"
onmouseout = "rollout('faq')"
<img src="{T_THEME_PATH}/images/buttons/faq1.png"
name="faq"
</a>
setrollover("{T_THEME_PATH}/images/buttons/faq2.png");
</script>
<!-- IF not S_IS_BOT -->
<a href="{U_TEAM}"
onmouseover = "rollover('team')"
onmouseout = "rollout('team')"
<img src="{T_THEME_PATH}/images/buttons/team1.png"
name="team"
</a>
setrollover("{T_THEME_PATH}/images/buttons/team2.png");
</script>
<!-- IF S_DISPLAY_SEARCH -->
<a href="{U_SEARCH}"
onmouseover = "rollover('search')"
onmouseout = "rollout('search')"
<img src="{T_THEME_PATH}/images/buttons/search1.png"
name="search"
</a>
setrollover("{T_THEME_PATH}/images/buttons/search2.png");
</script>
<a href="{U_MEMBERLIST}"
onmouseover = "rollover('members')"
onmouseout = "rollout('members')"
<img src="{T_THEME_PATH}/images/buttons/members1.png"
name="members"
</a>
setrollover("{T_THEME_PATH}/images/buttons/members2.png");
</script>
<td style="background:url({T_THEME_PATH}/images/header/h33.png);" width="20%" height="66" align="center"></td>
<td><img src="{T_THEME_PATH}/images/header/h34.png" width="100" height="66" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/header/h35.png" width="40" height="66" alt="" /></td>
<div id="wrapcentre">
<td>
<table style="height=45;" border="0" cellpadding="0" cellspacing="0" align="center">
<td><img src="{T_THEME_PATH}/images/p_menu/p_01.png" width="61" height="45" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/p_02.png) repeat;" width="20%" height="45"></td>
<td><img src="{T_THEME_PATH}/images/p_menu/cu_l.png" width="44" height="45" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/cu_m.png);" width="20%" height="45" align="center">
<h5>
<!-- IF S_DISPLAY_PM --> <a href="{U_PRIVATEMSGS}"> {PRIVATE_MESSAGE_INFO}
<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}
<!-- ENDIF --></a>
<!-- ELSEIF S_REGISTER_ENABLED --> <a href="{U_REGISTER}"> {L_REGISTER}</a>
</h5>
<h5>
<a href="{U_LOGIN_LOGOUT}"> {L_LOGIN_LOGOUT}</a>
<!-- IF U_RESTORE_PERMISSIONS --> <a href="{U_RESTORE_PERMISSIONS}"> {L_RESTORE_PERMISSIONS}</a>
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --> <span style="color: red;">{L_BOARD_DISABLED}</span>
</h5>
<h5>
<a href="{U_PROFILE}"> {L_PROFILE}</a>
</h5>
<td><img src="{T_THEME_PATH}/images/p_menu/cu_r.png" width="45" height="45" alt="" /></td>
<td><img src="{T_THEME_PATH}/images/p_menu/p_03.png" width="61" height="45" alt="" /></td>
<td>
<table style="height:45" border="0" cellpadding="0" cellspacing="0">
<td><img src="{T_THEME_PATH}/images/p_menu/p_08.png" width="61" height="45" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/p_85.png);" width="100%" height="45">
<td style="background:url({T_THEME_PATH}/images/p_menu/p_85.png);" width="10%" height="36" align="center">
<a href="{U_SEARCH_UNANSWERED}"
onmouseover = "rollover('search_unanswered')"
onmouseout = "rollout('search_unanswered')"
<img src="{T_THEME_PATH}/images/buttons/ut1.png"
name="search_unanswered"
alt="{L_SEARCH_UNANSWERED}" border="0"
height="36" width="133"
</a>
setrollover("{T_THEME_PATH}/images/buttons/ut2.png");
</script>
<a href="{U_SEARCH_ACTIVE_TOPICS}"
onmouseover = "rollover('search_active')"
onmouseout = "rollout('search_active')"
<img src="{T_THEME_PATH}/images/buttons/at1.png"
name="search_active"
alt="{L_SEARCH_ACTIVE_TOPICS}" border="0"
</a>
setrollover("{T_THEME_PATH}/images/buttons/at2.png");
</script>
<td align="center" width="60%">
<a href="{U_SEARCH_NEW}"
onmouseover = "rollover('search_new')"
onmouseout = "rollout('search_new')"
<img src="{T_THEME_PATH}/images/buttons/np1.png"
name="search_new"
alt="{L_SEARCH_NEW}" border="0"
</a>
setrollover("{T_THEME_PATH}/images/buttons/np2.png");
</script>
<a href="{U_SEARCH_SELF}"
onmouseover = "rollover('search_your')"
onmouseout = "rollout('search_your')"
<img src="{T_THEME_PATH}/images/buttons/yp1.png"
name="search_your"
alt="{L_SEARCH_SELF}" border="0"
</a>
setrollover("{T_THEME_PATH}/images/buttons/yp2.png");
</script>
<td><img src="{T_THEME_PATH}/images/p_menu/p_09.png" width="61" height="45" alt="" /></td>
<td>
<table style="height:40;" border="0" cellpadding="0" cellspacing="0">
<td><img src="{T_THEME_PATH}/images/p_menu/p_10.png" width="61" height="40" alt="" /></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/p_11.png) repeat;" width="50%" height="40"></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/clock.png);" width="350" height="40">
<p class="gensmallclock" align="center">
<script type="text/javascript" src="{T_TEMPLATE_PATH}/liveclock.js">
</script>
</p>
<td style="background:url({T_THEME_PATH}/images/p_menu/p_11.png) repeat;" width="20%" height="40"></td>
<td style="background:url({T_THEME_PATH}/images/p_menu/p_11.png) repeat;" width="30%" height="40" align="right">
<a href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a>
<td><img src="{T_THEME_PATH}/images/p_menu/p_13.png" width="61" height="40" alt="" /></td>
