Dead link to portal.php
Inspirit
phpBB.de User: Rob
phpBB.com User: Rob
Post by Inspirit »
Boardlink: http://inspirit.one-entity.com
PHP Version: 3.0.5
Nothing....finished installing, tinkered with the settings in the .MODS tab in ACP. Refreshed, Purged cache. I got a chance to see the Portal once or twice, but now I cannot. No changes were made to my directories, scripts or ACP.
Purging Cache, Refreshing, reuploading portal.php to my forum's root directory.
Not exactly sure what happened. After I successfully installed manually, and deleted the /install directory, I saw the portal live on my forum.
Then, after about 5 minutes, the link to portal.php went dead and I get the error:
The page cannot be displayed because an internal server error has occurred.
Not sure what the cause is. I didnt change anything in the script, nor did I do any major changes in ACP, except add on the paypal module.
Re: Dead link to portal.php
I get a 404-page. You might want to contact your hoster for this.
Inspirit
phpBB.de User: Rob
phpBB.com User: Rob
Post by Inspirit »
Everything is taken care of now. Quick question though, where do I redirect my url to go automatically to the portal, instead of the board?
Usually by editing the .htaccess as instructed in the install.xml.
If that doesn't work, you might want to contact your hoster for more info on how to make portal.php your homepage.
