Portal misaligned
.Sup
Portal misaligned
Post by .Sup »
Your Portal Version: 1.0.4
It was like as soon it was installed (I think)
Hi guys, I know nothing about coding so I'm asking for your help. Portal is installed but misaligned.
Have a look at this screenshot I made: Image
Portal on the left, board index on the right.
Thank you for any help!
Re: Portal misaligned
Looks like you need to adapt the style for the portal... But without a link we cant do anything ;)
.Sup
Post by .Sup »
Mike wrote:Looks like you need to adapt the style for the portal... But without a link we cant do anything ;)
What link do you need Mike? Let me know.
Hows about a link to your site, and another one to the style (download) ;)
.Sup
Post by .Sup »
Mike wrote:Hows about a link to your site, and another one to the style (download) ;)
Oh I'm a newb, You must forgive me Mike, I'm new to all this but I would really like to make our site work.
Here's the theme we are using: http://demo.phpbb3styles.net/DirtyBoard2.0
And the site: http://www.global-conflict.org/portal.p ... 3921bebfff
We made an identical copy of the site so we can poke around with the code and try to fix the Portal: http://staging.global-conflict.org/port ... d9a1055ec4
Thanks for looking into this problem Mike! :)
Hmm... on your site there is an Aero Style. So i cant have a look into the problem.
But i installed the Style on my Testboard, and i cant see any problems except the backroundimage cause the portal is too long ;)
http://area51.mikevil.de/portal.php?style=79
.Sup
Post by .Sup »
Mike wrote:Hmm... on your site there is an Aero Style. So i cant have a look into the problem.
How can I reinstall Portal Mike?
hmm... just delete the template folder, purge all caches, and upload all files from the Style and portal again...
.Sup
Post by .Sup »
Mike wrote:hmm... just delete the template folder, purge all caches, and upload all files from the Style and portal again...
I get this error when I want to visit the site after reinstall: "Language file ./language/en/common.php couldn't be opened."
The file seems to be missing - its not there where it says it should be.
If you just deletet the Folder of your Style this shouldnt be...
You can upoload this missed file again from your phpbb download.
.Sup
Post by .Sup »
Mike wrote:If you just deletet the Folder of your Style this shouldnt be...
OK its restored now. Mike what do you think- should I install everything from scratch: phpbb3>portal>theme and then all other addons on the portal so I see what's causing the problem? Because I can't pinpoint the problem.
No! You just need to install this Style from scratch. Deinstall it in ACP an delete the "DirtyBoard2.0" folder. Dont forget to clear all caches every time you make any changes... ;)
Knowledge Base: Changes to forums styles
EDIT: try to take my header and config before you make a new install:
_block_config.html
<!--version $Id: _block_config.html v1.0.4 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><h3>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul>' -->
overall_header.html
<head>
{META}
	phpBB style name: DirtyBoard2.0
	Based on style:   prosilver (this is the default phpBB3 style)
	Modified by:      CoSa NoStrA DeSiGn ( http://www.cosa-nostra-design.com/ )
// <![CDATA[
	var on_page = '{ON_PAGE}';
	var per_page = '{PER_PAGE}';
	<!-- IF S_USER_PM_POPUP -->
		if ({S_NEW_PM})
			var url = '{UA_POPUP_PM}';
	* Find a member
	function find_username(url)
		return false;
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
</head>
<div><a class="header_js" id="header" name="header" accesskey="t" href="#footer" title="Go to footer">Go to footer</a></div>
	<div id="submenu">
			<a href="#" class="sitehome" title="{L_HOME}">{L_HOME}</a>
			<a href="#" onclick="fontsizeup(); return false;" onkeypress="fontsizeup(); return false;" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a>
			<a href="{U_FAQ}" class="icon-faq" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a>
	<div style="clear: both;"></div>
	<div id="page-header">
		<div class="headerbar">
			<div class="inner"><span style="display: block; height: 5px;"><span></span></span>
			<div id="site-description">
				<h1>{SITENAME} <span style="font-size: 12px;">{SITE_DESCRIPTION}</span></h1>
			<div id="search-box">
 				<!--[if IE]><div style="margin-top:-1px;"></div><![endif]-->
				<fieldset>
					<input class="button2" value="GO" type="submit" title="{L_SEARCH}" />&nbsp;<input class="button18" onclick="location.href='{U_SEARCH}';"  value="+" type="button" title="{L_SEARCH_ADV_EXPLAIN}" />
					{S_SEARCH_HIDDEN_FIELDS}
				</fieldset>
				</form>
			<div style="display: block; height: 27px;"></div>
				<a href="{U_INDEX}" title="{L_INDEX}" id="logo">{L_INDEX}</a>
			<ul>
				<li><a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a></li>
				<!-- IF S_DISPLAY_PM --><li><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></li><!-- ENDIF -->
				<li><a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></li>
				<!-- IF U_RESTORE_PERMISSIONS --><li><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a></li><!-- ENDIF -->
			<!-- IF not S_IS_BOT -->
				<!-- IF S_DISPLAY_MEMBERLIST --><li><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
				<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
				<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li>
			<span style="clear: both; display: block; height: 5px;"><span></span></span></div>
				<li class=" icon-home bold"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a>  <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<div id="wrap">
				<li class="rightside"><!-- IF U_EMAIL_TOPIC --><a href="{U_EMAIL_TOPIC}" title="{L_EMAIL_TOPIC}" class="sendemail">{L_EMAIL_TOPIC}</a><!-- ENDIF -->&nbsp;</li>
	<div id="page-body">
.Sup
Post by .Sup »
Mike you are a genius!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I only had to replace overall header!
Danke mein freund, du bist der beste!!!!!!!!!!!!!!!!!!!!!!!!!
:D
I hope I got it right or 10 years of learning German went to waste :p
Im glad i could help you...
And yes you got it right... i wish i could speak almost as good english as you german ;)
.Sup
Post by .Sup »
Mike wrote:Im glad i could help you...
But you do my friend, you do ;)
