![Lächeln :)](./images/smilies/icon_e_smile.gif)
Blocks showing incorectly on Forum pages
Moderator: Dyo
I have installed this mod and in my config I have disabled the Birthdays block. When I'm on the portal page they do not show (correct
) However, if I go to the Forum the Birthday block is shown. Any ideas?
Re: Blocks showing incorectly on Forum pages
try disableing it directly in ur phpbb seeing as you have done it in the portal already
ACP > General > Board configuration > Board Features > Enable birthday listing
> set this to NO
> set this to NO
Great thanks
Hello everybody.
Juste one word before problems, to tell tou yhat I love this Mod !!!
... except the little problem which seems to be quite the same as yours :
I have desactivated the birthday block in the ACP. When you are on the index.php page, the block is back ! And the Welcome block and Paypal block are gone...
http://mathslfm.comuv.com/index.php
The most strange is that there's no problem on the portal.php page... very strange...
http://mathslfm.comuv.com/portal.php
So sometimes when you redirect automatically it's on the index page and you see the birthday block and you don't see the others (Paypal and welcome block).
Does anybody have an idea about this ?
Thanks a lot![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
Thanks a lot
Hello !
I've solved the problem by a radical solution :
Simply by copying all th file "portal.html" to "index.html", so that I have the same file twice, but it works well like this...
Thanks![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Thanks
