Your Portal Version: 1.0.4
Boardlink: http://maverickrenegades.co.uk
I have just updated my portal from 1.3 to 1.4 as per the instructions and I stupidly forgot that everything would vanish from the portal page that i had previously done. So I started to update my mods starting with application center and now under my mods tab all the links to my other mods have vanished.
Im hoping that this is something really simple that I have overlooked as otherwise I'm screwed, as my backups are not up to date.
I have a number of blocks installed but none of them display either but im sure thats down to just having to update template files for them to show im more concerned about why everything seems to have vanished in my admin panel under mods tab except my announcement center links.
nothing works anymore
Re: nothing works anymore
It's ok folks I figured it out.
