se_pro
se_pro
Demo
_block_config.html
<!--version $Id: _block_config.html v1.0.4 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 4px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul>' -->
open / öffne:
styles/se_pro/template/portal/portal_body.html
find / finde:
		<!-- please keep this credits visible, thank you!  -->
replace with / ersetze mit:
		<br /><div style="color:black; text-align: center">{L_PORTAL_COPY}</div>
