Arcade Not showing
blastman
phpBB.de User: blast
phpBB.com User: blast
Arcade Not showing
Post by blastman »
Hello my name is Justin and i recently installed this mod http://www.phpbb.com/community/viewtopi ... 0&t=685225 onto my site http://test.solid-gaming.com which i found by going threw your site i followed the install.xml to the "T" but my arcade isnt showing anywhere on my portal ? any help would be much appreciated as i cant figure out why this isn't showing on my portal.
MY SPECS
phpbb 3.0.5
MODS
board 3 portal 1.0.4
arcade 1.0.RC9
p.s I did notice that at the end of the install it says to "Next make sure to follow the template edits." but i see no where in the install.xml where it tells me where, how and what to edit as far as template stuff goes. farther more I used the styles/prosilver files from this arcade zip....
Thanks in advance for the help :)
Justin
blastman
Re: Arcade Not showing
Post by blastman »
BUMP* I need help with this ....l
blastman
Post by blastman »
A little help would be nice .......................................... :?: :?: :?: :?: :?: :?: :?: :?: :?: :?: :?: :?: :?: :?: :?:
Anthies
phpBB.com User: anthies
Post by Anthies »
blastman wrote:Hello my name is Justin and i recently installed this mod http://www.phpbb.com/community/viewtopi ... 0&t=685225 onto my site http://test.solid-gaming.com which i found by going threw your site i followed the install.xml to the "T" but my arcade isnt showing anywhere on my portal ? any help would be much appreciated as i cant figure out why this isn't showing on my portal.
MY SPECS
phpbb 3.0.5
MODS
arcade 1.0.RC9
Justin
First of all, I would recommend converting your board to 3.0.6. Most arcade mods are compatible with 3.0.6.
Your arcade mods will be shown in the portal if you did the edits for your styles thoroughly but well. However, if you're using another styles than prosilver or subsilver2, make sure you do the edits for prosilver or subsilver2 as well. If your style is based on either one of the styles, do as I said.
Regards, Anthies
Download my smilies package: HERE
Subsilver2 based useful code snippets: HERE
