Nothing. See below
Search many forums but not getting the answer I need
I'm having trouble installing this because I am not able to edit the .htaccess file
I have tried opening it with Notepad but it just shows a blank page. Nothing to edit.
Any clues on this?
Is it a necessary edit?
Thanks
.htaccess editing
Re: .htaccess editing
Anyone help??
To modify the software to take: "Notepad++" at http://notepad-plus.sourceforge.net/de/site.htm.
Just try to the file for your:
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
Thanks, I'll give that a try
hello, i edited the .htaccess file, but the frontpage goes to forum and not portal. Any ideas?
