installing on localhost
robgib
phpBB.com User: robgib
Post by robgib »
n/a
nothing as yet
installing the board on a local host using automod.........
got some manual edits to do with the automod
which i have done correctly
when maually editing the includes/functions.php
// The following assigns all _common_ variables that may be used at any point in a template.
Add Before
	$user->add_lang('mods/lang_portal');
	include_once($phpbb_root_path . 'portal/includes/functions.'.$phpEx);
Success
'U_PRIVATEMSGS'			=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&folder=inbox'),
Add Before
		'U_PORTAL'				=> ($portal_config['portal_enable']) ? append_sid("{$phpbb_root_path}portal.$phpEx") : '',
Success
i am getting this error when returning to automod
Parse error: syntax error, unexpected '{' in C:\xampp\htdocs\forum\includes\functions.php on line 3762
i have double checked the edits.............
which is the offending character???[/i]
robgib
Re: installing on localhost
Post by robgib »
just checked the manual install instructions in the modx file
and there are some characters missing from the end of the instruction line in the automod required manual edits layout !!!
have fixed this and now getting
a diff error
Fatal error: Language file ./language/en/mods/lang_portal.php couldn't be opened. in C:\xampp\htdocs\forum\includes\session.php on line 2034
