Black Smoke Style
- phpBB.de User: blast
- phpBB.com User: blast
Re: Black Smoke Style
thanks worked like a charm
error sorry
Is there an easy way of increasing the right hand column width size or a way to fix it so it doesn't break the layout when you add something with say a 220px width?
heres an example
Adjusting the block width in the ACP did not work/help.
Changing the wrap in common.css helped but then caused the header image to repeat which can be seen Here
Any ideas guys?
heres an example
Any ideas guys?
If you increase its width it should gone wider to the middle of the portal. The Problem is, that this is a small style wich has no place to decrease the center blocks, so the right blocks breaks out of the portal. If you want to do this, you should use a style which use the whole browser and has no fixed width.
Is there a simple way though to stop the header image from repeating but allowing the border to?
