Black Smoke Style
- phpBB.de User: blast
- phpBB.com User: blast
Re: Black Smoke Style
Ok updated >>>>http://test.solid-gaming.com/ Thanks very much mike for all your time and help with this it meen very much to our community and i will be sending ya some GREEN shortly thanks again
Go to your ACP -> Portal -> news -> Display the number of replies and views: -> NO
This should make your news Block looks better
Ah, and You're welcome!
one last thing mike when you look at the board index it has a dark brown black and then when you scroll over the forum it goes solid black ... is there a way to make the inner portal blocks be that brown black ?
The Backgroundcolor of Center Blocks is not a part of the config, since there are some differences between each block.
This is what you can do with the config : http://area51.mikevil.de/portal.php?style=66
If you want more, you have to change the colors in the stylesheets for the whole Style...
open colors.css and search for
If you change this to #000000 you will have the black backround in most center Blocks too
But this is not advisable since you change this color for the whole Style. Maybe theres a place where is looks ugly then
.bg1 { background-color: #1a1a1a; }
thank you also mike i have a post in modification support and nobody has replied in two days
Hey I don't suppose Mike or blastman could link me(in this thread or pm) to a link for this style with the edits for board3?
You cannot download this Style as a complete adapted package. You have to do the changes by yourself.
An Instalinstruction for this and other Styles will follow over the time. But at the Moment ive got noi time for it, so you can take the Header and config from this Thread.
mike please take a look at this as i installed the portal onto my primary domain and now things dont seem to look right http://www.solid-gaming.com/
I did not see anything... No Portal, no forums...
Hi Mike, I have follow all the instruction is given here .. but no succes to make it work.
http://www.team-quebec.org/portal.php?style=7
This is horrible
2 different view .. Explorer 8 and Firefox
Thx for support!
This is horrible
Thx for support!
Re: BlackSmoke
better in a fresh installation but samething with portal look in Explorer 8
in firefox its look ok but center latest news dont look clean like yours
I moved your Post, since we dont need to discuss this in two topics
Did you refreshed your caches? Cause i testet this and it erases the error with the header in center blocks...
EDIT: in my IE8 an FF your site looks the same as mine... with nor errors...
EDIT2: try to set ACP->Portal->News->Display the number of replies and views: NO
Yes .. I refresh template, theme, imageset and clear cache.
test on 2 computer ...same look
Samething for me.
Samething for me.
Did you talk about http://test.team-quebec.org/portal.php?style=2 or http://www.team-quebec.org/portal.php?style=7
Cause the style=2 looks great for me. In both IE8 and FF but style=7 has the error with the headers...
Did you read my edits?
