Black Smoke Style
- phpBB.de User: blast
- phpBB.com User: blast
Re: Black Smoke Style
your speaking a language i dont get lol I do know i have copied the files board3portal_1_0_3\root\styles\prosilver to the styles in my phpbb3 styles/prosilver so any way you can help me to understand step by step what i need to do from here ?
Heres what i have come up with can you hale me to fix a few things with making it work properly ?
http://test.solid-gaming.com/portal.php?style=4
You have to copy the files from board3portal_1_0_3\root\styles\prosilver to styles/BlackSmoke
After that go through the install guide from prosilver, but do the changes in the files for BlackSmoke...
Maybe you cant figure out where to add the changes, since the files are different from prosilver. But if you just copy the files, and add portal.css to stylesheets.css it should look like this: http://area51.mikevil.de/portal.php?style=66
Here is my overall_header.html so you just have to copy & paste (replace) it into your overall_header.html
What you need is just an block_config.html file which i can make this evening...
<head>
{META}
phpBB style name: prosilver
Based on style: prosilver (this is the default phpBB3 style)
Original author: Tom Beddard ( http://www.subBlue.com/ )
Modified by:
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jquery-1.2.6.pack.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jQuery.flash.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jquery.scrollTo-1.3.3-min.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jquery.localscroll-1.2.6-min.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/hoverIntent.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/superfish.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/supersubs.js"></script>
$(document).ready(function(){
$.localScroll();
$("ul.sf-menu").supersubs({
minWidth: 12, // minimum width of sub-menus in em units
maxWidth: 27, // maximum width of sub-menus in em units
extraWidth: 1 // extra width can ensure lines don't sometimes turn over
// due to slight rounding differences and font-family
}).superfish(); // call supersubs first, then superfish, so that subs are
// not display:none when measuring. Call before initialising
// containing tabs for same reason.
</script>
</head>
<div id="wrap">
<div id="flashcont"><div id="flash"></div></div>
<div class="border-left">
<div class="border-right">
<div class="border-top">
<div class="border-top-left">
<div class="border-top-right">
<div class="inside" style="direction: {S_CONTENT_DIRECTION}; ">
<div id="page-header">
<div class="headerbar">
<div class="inner">
<div id="site-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<div id="search-box">
<fieldset>
<input name="keywords" id="keywords" type="text" maxlength="128" title="{L_SEARCH_KEYWORDS}" class="inputbox search inputbox2" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" />
<input class="button4" value="{L_SEARCH}" type="submit" /><br /><br />
</fieldset>
</form>
<div id="welcome">
<!-- IF not S_IS_BOT -->
<a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a> -
<!-- IF S_USER_LOGGED_IN --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>) <!-- ENDIF -->
- <a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a>
<div id="sf-contain">
<!-- INCLUDE menu.html -->
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<div id="page-body">
<a href="javascript:jQuery.flash.subtle('Details | Click to close ', 'This is a detailed information bar you can place on any area of the style.')"><img src="{T_THEME_PATH}/images/tip.png" alt="View Details" /></a>
Reason: proper code, so the footer isnt crashed anymore
oh wow that style looks great much thanks for the help mike ill send 10 bucs your way via paypal for the help
and again thanks
mike
I did a fresh install of the portal onto the blacksmoke style and i get this error again
template->_tpl_load_file(): File ./styles/prosilver/template//portal/portal_body.html does not exist or is empty
Hmm... looks like the same problem... on a fresh installation, you have to upload the content of the whole "root" folder into your phpbb root. Then you will have the requestet files on prosilver and subsilver2 Templates.
If you want to have more Styles, you need to find out on which Style your new Style is based on, and copy the according files. (as you have done in blacksmoke)
I added new Headers to the center Blocks on my Testboard: http://area51.mikevil.de/portal.php?style=66
Tell me, if you like it
that looks very very nice i was goin to ask if that could be done to allll blocks
also the style i am using is blacksmoke and i have tryed to install alllllllll the root files to my phpbb root>> board3portal_1_0_3\root\styles\prosilver to my root/test/styles/blacksmoke and i edited the files as well.... and used your headercode but still same general error
Did you copy the prosilver folder into blacksmoke, or just the content of the prosilverfolder?
You just have to copy the two folders "template" and "theme" into your blacksmoke folder.
Remember that you have to purge all caches if you edit template files...http://board3.de/knowledge/kb_show.php?id=28
Ok mike i figured out what i was doin wrong i have no installed the portal on the blacksmoke style but few things look out of line like theres little orange circles that are outside the portal blocks
This happens if you dont upload portal.css, or forget to add it to stylesheet.css, or forget to clear all caches
if you take a look at my portal http://test.solid-gaming.com i have white back rounds in some blocks..... also anyway you could help me to make those center blocks as well as make the left and right blocks have that nice header on them
No, it wouldnt work in the outer Blocks, since the Backroundimage has a fixed width. Let me try to make it without this Image, but with the rounded corners...
White backround: maybe this is caused by the actual version of B3P... (I had some similar Trouble with other Styles)
In a few Days we rush out the new one (1.0.4) which i am using on my testboard without such errors...
ok nice well i will wait until the new one comes out before i use this on my actual website also once you get this customized block stuff figured out you mind sending it to me
thanks mike
OK... i made it: http://area51.mikevil.de/portal.php?style=66
Let me know if it is ok for you.
PS: new Version is out now
PS1: there was an error in the Header code i posted... i correct it, and now the footer istn crashed anymore;)
PS2: may you use the dark Clock, since it looks way better: styles/board3portal/theme/images/portal/board3clock.swf (rightclick -> save under)
Very nice work mike
yes i have already downloaded and installed the portal 1.0.4 i was the 25 person to download
it fixed the white backgrounds as well
also your blocks look very very nice what about adding a rounded bottom to the blocks is that possible ? and i agree the silver clock looks very good ill switch mine asap but heres the newest 1.0.4 on my board
http://test.solid-gaming.com/ thanks for all the help and work mike.
Now with rounded corners at the bottom
You have to change the code for your Header, because your footer is still crashed... I update the code in my prior posting.
Here is the actual config for this style: (works with 1.0.4 only)
viewtopic.php?p=18653#p18653
Reason: proper version
