Fatal installation error
EAnushan
phpBB.com User: EAnushan
Post by EAnushan »
Your Portal Version: p3p 1.22
Boardlink: local board not live yet
Tried to upgrade from PHPBBPortal 1.2.2 to Board3 Portal 1.0.3
Tried to run some functions independently, but I'm afraid I may have done it wrong.
I have a board with PHPBBPortal 1.2.2 installed on it. I was planning to upgrade it to Board3 Portal 1.0.3. I've done all the necessary edits and everything seems to be fine until I get to the part where I have to run the installer (navigating to the install folder).
I get this message:
index.php [ 274 ]
Module "" not accessible.
This message occurs after the Remove phpbb3 Portal step. I click the "Proceed to next step" button to proceed to the "Create Database Tables" step. That's when I get this error. I hope someone can help.[/i]
EAnushan
Re: Fatal installation error
Post by EAnushan »
Just my luck that I fix it 2 minutes after I post this lol.
Well this is how I did it:
  1. Navigate to the root/install/ directory.
  2. Proceed to the "Remove phpbb3 Portal" step. DO NOT go any farther. (The error will occur)
  3. Navigate back to root/install/ directory.
  4. Now you will be given the option to have a fresh install for the portal.
This is just a quick fix, and I'm not sure if settings are saved (their easy enough to set back anyway). Anyhow, I think it may be a problem with the installer for going from PHPBB3Portal to Board3Portal 1.0.3. Hopefully someone can confirm or deny this and fix it if needs be.
channelasian
Post by channelasian »
wow... thanks alot. it helped me out as well. i also got the same problem. but finally, it works after followed your way.
