I have started to port over and finish my WoW Recruitment Page.
You can take a look and even complete the form as it stands right now @
http://test.iron-circle.com/recruitment ... e=post&f=2
The mod is not finished so i'm not looking for bug reports. But if you have a suggestion on new features to be added or the look or anything else feel free to post it here.
(until the ACP is complete you can only choose Alliance races)
Note: After the WoW version is done, I can make version for other games.
Thanks all
WoW Recruitment Page w/ ACP
Teksonic
- phpBB.com User: Teksonic
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
Dr Nick^
- Valued Contributor
Re: WoW Recruitment Page w/ ACP
Yow.
i stole your idea, released the first kind of app form. then you come with this!
damn could work with more time. but this is nice
its a lot of work filling everything in. (if filling in in thruth)
And 'Tab' doesnt work well in your form, so you need to click on each field you wanna fill in.
are these fields also able to be modded in ACP ?
also its not clear that you are logged in, no log out button, and not realy a go back to portal button or something (execpt logo ofc)
nice job on adding a table in your post, even nicer that it works
on that manner you can sort the progress very nice.
Just my 2 cents
*edit*
Clicking on the big text fields causes an JS error.
Error: storeCaret is not defined
File: http://test.iron-circle.com/recruitment ... e=post&f=2
Line: 1
comes with tabbing, selecting, and only textarea's.
*/edit*
Just my 2 cents
*edit*
Line: 1
*/edit*
Teksonic
yep, tabbing isn't ordered correctly it's setup and in the form.. but not ordered at all.
all in all there's still a lot to be done with it. it's not going to be ready for awhile.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
Weastbug
- phpBB.de User: none
- phpBB.com User: Weastbug2
No news about this mod ?
talonos
- Portal Specialist
- phpBB.com User: talonos
hey teksonic,
its looking brilliant upto now m8, keep up the goodwork
Teksonic
sry mod got back burnered as I worked on some other things including the Raid Progress mod. This is still in development, but as if yet there is still no ETA.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
talonos
- Portal Specialist
just so u know m8 char linking from the wowhead tooltip script works well with your application form
http://test.iron-circle.com/viewtopic.php?f=2&t=37
i don't know if this is something u'd like to add but i'm sure if this one works the others will aswell like the wowhead profiler n such
[armory loc="eu,Stormrage"]Talonos[/armory]i don't know if this is something u'd like to add but i'm sure if this one works the others will aswell like the wowhead profiler n such
Teksonic
Interesting, good catch Tal.
Maybe i'll incorporate the wowhead script into that mod also.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
beermeat
- phpBB.de User: beermeat
- phpBB.com User: beermeat
Hey, I have been searching for a good addon/module and when I found this one I did some reasearch and it looks awesome... I updated my PHPbb to 3.0.5 just so I could do this, followed everything through, then when I got to the part that says go to:
Load up your forums then go to - ACP >> System >> Administration Control Panel >> .Mods >> Portal
I dont have Portal there... do I have to enable it? Install it?
Dont know if you can even help...
My website is http://www.gestaltguild.net/forums
Thanks!
Thanks!
Teksonic
How exactly did you install this? I haven't even finished it yet, or posted files to be used for an install.
Guild - Iron Circle
Server - Llane
Guild - Iron Circle
Server - Llane
