Raid Progress Block w/ACP
Teksonic
Portal Enthusiast
phpBB.com User: Teksonic
Re: Raid Progress Block w/ACP
Post by Teksonic »
well from what i can see you don't have the icon's uploaded.
the file points to this location on your webserver
/forums/styles/pbwow_cataclysm/theme/images/raid_progress/voa.png
and there are no files in that folder, i'm assuming they have been uploaded to an incorrect spot, or not uploaded at all.
as a side note they work while using the pbwow theme. so i'm guessing that you only uploaded the files to one of your theme's folders not all of them
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
as i said note i will change the location of the icon's for the next major version so we don't have this kind of issue going forward. nor will there need to be a multitude of icon's in ever theme's image's.
Guild - Iron Circle
Server - Llane
Vatras
Post by Vatras »
thx for help:)
Teksonic
Portal Enthusiast
Post by Teksonic »
gonna get a new version of this up soon. with some bug fixes and changes. sorry for the delay guys.
Guild - Iron Circle
Server - Llane
ghostman
Post by ghostman »
emjh wrote:Using the latest version of this block (2.2.0) with the latest PHPBB version (3.07-PL) and the latest Board3 (1.0.5), I am getting a pretty serious error that makes it so I really can't use this block.
What happens is, when logging in as admin (from guest), and then trying to access the ACP, an error occurs, not allowing access to the ACP.
The error is as follows : Fatal error: Class 'template_compile' not found in /home/site/public_html/forum/includes/template.php on line 314
Sometimes, after several refreshes, it goes through, and takes me to the screen that asks me to re-type in my admin password, this page is white, theme-less and has no graphics... looks all glitchy, etc. I can eventually reach the ACP after a few more refreshes.
I have narrowed this issue right to this mod, as using a fresh install of phpbb and installing it causes the problem, and then uninstalling it fixes the problem.
I've already tried disabling the version checker, no dice.
Aha, so it was this mod that crashed my testboard. :twisted: After a sucess install and a few adjustments in the ACP, it suddent crashed and told me it could not find some of my gallery files :P ... files I was sure existed ;) ... I am glad the mod dident get longer than to my testboard ;) ... Looking forward for an update :D
Teksonic wrote:(thanks to ghostman for mentioning an another project i used to work on, which made me think about this new feature)
You're welcome :)
/Ghostman
jeremyrayl
Post by jeremyrayl »
Hello.
I recently installed this and everything is working correctly in the block but I seem to be having a problem finding the part in admin panel on editing the raids. All I can locate is what is in the screen shot. Please advise
ghostman
Post by ghostman »
You should also have those menues (Linked from the first post)
I see you have made your own tab for raidprogress, I think you lost some menus by doing that.
But go to http://www.teksonicmods.com/ and ask Tech on his support site ;)
/Ghostman
jimmydanny
Post by jimmydanny »
http://www.vagabonds-kt.com/styles/nexu ... 5282os.png
Why does it add sessionid to the link?
EDIT: Bah, I removed append_sid in raid_progress.php :) Worked nice. If it should be right, it should be ?sid=213213213/pic.png, not ?sid=12312312pic.png.
Is this fixed in the newer versions?
Evanonian
phpBB.de User: Evanonian
phpBB.com User: Evanonian
Post by Evanonian »
Hey Teksonic,
First, I'd like to say thanks for the great Modifacation I like it a lot!
I'd also like to ask, when you release a new version will it contain "The Ruby Sanctum" ? ;)
Thanks,
Teksonic
Portal Enthusiast
Post by Teksonic »
Hey guys, ya the new version will have the new raid in it. Hopefully I can get that up this week, and get all the fixes in place that we have gone over since the last update.
wanna say thanks for waiting this out and not complaining about my updating speed. IRL has been fucking busy lately, was shipped off for the last month for advanced weapon training been sleeping in a hole firing machine guns, rocket launchers and hussing grenades around. didn't even have a computer to check up on shit..
Guild - Iron Circle
Server - Llane
focb
Post by focb »
Hi there!
First of all many thanks for a great module!
I have successfully installed the raid progress block and it all appears fine, BUT - only when logged in or using another theme!
If you go to http://www.immortal-hellscream.net you will see that the mouseover popup works, but the progression icons (crosses and ticks) do not show, as well as the instance icons.
I have checked that the images are available in the /theme/images/raid_progress folders for each style that my site uses (pbwow/pbwow_cataclysm/pbwow_wotlk).
If you change the style using the drop-down menu or if you refresh the page, it works - that is the unusual thing. Then, if you change back to the previous theme (most likely because they're cached) the images work fine again also.
Any thoughts?
Also, can you give brief instructions on how to create a new entry for Ruby Sanctum, and for Toravon? I can create a new icon no probs and would be also happy to then hand the changes over to you to post as an update.
Thanks!
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
focb wrote: If you go to http://www.immortal-hellscream.net you will see that the mouseover popup works, but the progression icons (crosses and ticks) do not show, as well as the instance icons.
this is to do with sid in the image code inside of wow_progress.php. this will be fixed in next version which should be released soon
focb
Post by focb »
Great - thanks very much for that :)
malvack
Post by malvack »
Evanonian wrote:Hey Teksonic,
Thanks,
I did it my way :P Not happy with the icon tho :( (Swedish site)
http://seraphimguild.eu/forum/portal.php
What font do u use??
talonos
Portal Specialist
Post by talonos »
for people with images not loading please read THIS post.
