Raid Progress Block w/ACP
Clausi
Re: Raid Progress Block w/ACP
Post by Clausi »
Nice work on this block, I like it.
I hope your next update will contain "Koralon the Flame Watcher" in the Vault of archavon. :)
Teksonic
Portal Enthusiast
phpBB.com User: Teksonic
Post by Teksonic »
Clausi wrote:Nice work on this block, I like it.
I just saw yesterday that he was available. So yes it most defiantly will.
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
I'm building a new version currently it will contain...
1. An Updater and Uninstaller
2. Yogg / Vezax Hard mode's
3. The new Vault boss, Koralon the Flame Watcher
The bosses are in. the Uninstaller is tested and working great. The only thing left is to test the upgrader.
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
Version 2.0.0 is available from the first post.
To upgrade from any previous version, simply upload and replace the core files, and run the installer. from http://<your site>/install/ choose upgrade and away you go.
To Do:
Add a new function to the ACP to allow you to customize the color of the "Block Title" and raids in case your theme doesn't color them correctly.
Add a "Version Check" into the Main Options section of the Raid Progress Block's ACP, that way you will always know when there's a update available.
Enjoy
Guild - Iron Circle
Server - Llane
Teksonic
Portal Enthusiast
Post by Teksonic »
Finished and tested the Version Checker.
There is also a direct link in the ACP to reach here for help, support, and downloads ( in the case of a new version ).
Guild - Iron Circle
Server - Llane
Swinder
Post by Swinder »
How can I switch;
Normal ~ (13/13)
Hard Mode ~ (2/14)
Heroic ~ (12/13)
Hard Mode ~ (1/14)
into...
10 Normal ~ (13/13)
10 Hard Mode ~ (2/14)
25 Normal ~ (12/13)
25 Hard Mode ~ (1/13)
This only affects the Ulduar section.
I wish to do this to maintain a nice tidy layout throughout the block.
Also when Vault of Archavon is enabled the text says 0/2 instead of 0/3 - however the java script popup displays all 3 bosses.
Teksonic
Portal Enthusiast
Post by Teksonic »
Swinder wrote:How can I switch;
Normal ~ (13/13)
Hard Mode ~ (2/14)
Heroic ~ (12/13)
Hard Mode ~ (1/14)
into...
10 Normal ~ (13/13)
25 Normal ~ (12/13)
The block's .html file would have to be changed to customize the Ulduar block like that. I can change it for you if you like and provided a copy.
as to the vault section let me look into that. I'm assuming I didn't update the Lang file. But i'll check.
Guild - Iron Circle
Server - Llane
Swinder
Post by Swinder »
If you wouldn't mind making the edits and providing a copy that would be highly appreciated.
I took a quick look myself and didn't actually see what needed to be changed in order to get it to do what I want.
Teksonic
Portal Enthusiast
Post by Teksonic »
This should fix your two issues. Uncompress these and upload them over your copies.
Make sure to set your boss kills again after uploading this file. ( ACP -> Raid Progress -> Vault Of Archavon , Even if there already set simply hit submit. )
Download => acp_raid_progress.php.rar (right click save as)
This is for the change to the block itself. I have given you a prosilver and subsilver template here, use which ever one your theme is based off of.
Download => raid_progress.html.rar (right click save as)
You may need to increase the size of your column by a couple pixels to make the block not wrap that section with these changes. I will off course include these changes in the next version.
Guild - Iron Circle
Server - Llane
Swinder
Post by Swinder »
Ok I uploaded the new files and make sure to re-submit the details and the VoA bit now displays correctly, although there is an issue with the Subsilver2 .html file.
I purged the cache and manually removed cache to ensure nothing was affecting it and no changes appeared, however I decided to add the Prosilver .html file instead to double check the code. Now the code worked but obviously the style didn't due to mine being based on Subsilver2.
I did a quick flick through the new subsilver2 .html file and didn't come across any changes when compared with the one released in the download, I can only assume the wrong one was incorrectly rar'd and posted?
Thanks in advance
Teksonic
Portal Enthusiast
Post by Teksonic »
Bah
You are correct I rared the wrong one. I have replaced the download with a correct one. grab it again and you should be fine.
Also I have added a File and instructions for anyone to who would like to help translate the mod into other languages. See the OP for more info.
Guild - Iron Circle
Server - Llane
Swinder
Post by Swinder »
Works perfectly, thank you ever so much for both your time and of course the excellent mod.
Teksonic
Portal Enthusiast
Post by Teksonic »
Not a problem at all.
@ Everyone
If you are using my mods. I will be starting a list in the original post with all your guild names and links, this serves two purposes.
1. It can be used by others to look at my mods on live sites. As everyone's site is different and some ppl tweak my mods, look, language etc. it gives other a better idea of what the mod is and can do and how it looks on a live active site. Much better then my test site or pictures could ever tell them.
2. It will drive traffic to your individual site's, allowing you to show them off, show off your guild and of course your accomplishments, item's collected, bosses beaten etc.
I'm going to be starting this here, and I will be including it in upcoming mods also. So feel free to post your guild's website link. If your site is missing and you would like it added, drop me a message. :)
Guild - Iron Circle
Server - Llane
Xorakk
Post by Xorakk »
I have a little problem.
I can't disable Onyxia.
If i turn Ony to on everything is ok.
If i turn Ony to off only the text is gone. The Image is still there.
(At the moment i have Ony on)
Teksonic
Portal Enthusiast
Post by Teksonic »
hmm i just checked and your right seems with the new version something broke the Onyxia section. let me fix that and i'll put up the a new version today with all the new changes and fixes from the last little bit.
Guild - Iron Circle
Server - Llane
