Link zu Deinem Forum: http://www.ziegelhofstrasse98.at/forum
installed the board3 mod
double checked modifications
I did all the board3 modifications (also for german support and subsilver2). After that I called .../forum/install and got this:
Allgemeiner Fehler
Language file ./../language/de/mods/install_portal.php couldn't be opened.
Bitte informiere die Board-Administration oder den Webmaster: webmaster@ziegelhofstrasse98.at
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
After double checking and making some corrections to the modified files I'm getting the following when I run .../forum/install:
Fatal error: SQL ERROR [ mysqli ]
Table 'db_reksoft2.phpbb_portal_config' doesn't exist [1146]
SQL
SELECT config_name, config_value FROM phpbb_portal_config
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: portal/includes/functions.php
LINE: 32
FILE: includes/functions.php
LINE: 3735
CALL: obtain_portal_config()
LINE: 3360
CALL: page_header()
FILE:
LINE:
CALL: msg_handler()
FILE: includes/session.php
LINE: 1802
CALL: trigger_error()
FILE: install/index.php
LINE: 35
CALL: user->setup()
in /nfs/web/users/reksoft2/www/forum/includes/db/dbal.php on line 657
is there any configuration file which was created by the first faulty install? Can anybody help or advise me what to do? I checked the mod files several times. I guess they are ok...
Regards,
Martin
SQL error when running installation routine for board3
Re: SQL error when running installation routine for board3
if a previous install failed,
make sure you delete all DataBase parts again,
since he is not writing it over. (it looks like that is happening)
gl
gl
thats what I thought as well, but there are no additional database tables like phpbb_portal...
or do you want me to delete ALL phpbb_ entries in the database?
regards,
Martin
regards,
Martin
nah that should not do the trick,since thats all phpbb then,
not from portal. but it should create a db, called phpbb_portal_config
since that is what error is saying. so guessing something went wrong before install?
sure connection etc is good with right tables/passes you name it ?
(if you manual create it, i think it still doesnt work, since there needs to be data in it)
the phpbb itself worked well before the mod. and when I "unmod" it it worked again well...
in other words: the sql tables where created by phpBB but no additional tables where created by the board.
whats' next?
whats' next?
