Adv. Statistics block causes PHP error messages in Portal!!
tridient
phpBB.de User: tridient
phpBB.com User: tridient
Post by tridient »
Your Portal Version: 1.0.3
Boardlink: http://stopsense.com
installed the portal, even before that installed User Blog Mod and Advertising Management (all latest)
go over install instructions. everything seems proper.
The problem is this. Upon the finish of installation, I went to portal, where I was met with the broken layout and error messages. I then went to control panel, where I disabled several blocks.
I DID refresh the cache and all three style caches. Still no luck.
I established that the problem lies with the Advanced Statistics block - turning it off makes the site look as expected, and no error messages are given. However, disabling it isn't really an option.
Thus - any suggestions? I reckon it's an internal conflict somewhere, as opposed to it being code error of my own making during install. I have 2 other mods, maybe they are to blame?
Thanks!
tridient
Re: Adv. Statistics block causes PHP error messages in Portal!!
Post by tridient »
Fixed, there was some rogue code in statistics bock.
