king_conan style problem
apock
Post by apock »
Your Portal Version: 1.0.3
Boardlink: http://elysium-guild.dk/test/
PHP Version: 3.0.4
MySQL Version: MySQL 4.1.21
I'm trying to fit the style king_conan to Board3 portal 1.0.3 by using the _block_config.html from this post viewtopic.php?f=36&t=2166&hilit=king_conan&start=15 by Mike.
However I keep ending up with the portal blocks spanning across the theme borders, see http://elysium-guild.dk/test/ - as u can see i changes the width to 98%, but the problem was the same in the original width.
I have tried using all the _block_config.html i could find on this forum without any luck. If you have any suggestions or a solution :D - i would be very thankful.
Problem solved, was looking in the wrong place. It was the overall_header.html. :oops:
Return to “Styles Support”
