Change some color in news block
AlexanderPD
Post by AlexanderPD »
Your Portal Version: 1.0.3
Boardlink: http://pdx.altervista.org
problem was here from the beginning.
modding the portal.css file, but it don't work in a subsilver2-based style
a screenshot can descrive my problem better than words (because i'm not good in english :P )
How i can change that "text color" and that "background color"?
i already tried editing the portal.css but it doesn't work with this subsilver2-based skin. How can i change those thing?
Thank you! ;)
Re: Change some color in news block
As first have a look at this: http://area51.mikevil.de/portal.php?style=4
If you want your Board to look like this, see here: viewtopic.php?f=42&t=2077
Ok, lets have a look at your Problem...
Your can change this Color in your stylesheets.css.
find:
.row2 {
	background-color: #E4F4FE;
	padding: 4px;
But this change the color for the whole Style, not just for this single Block.
And your textcolor problem... i seems already solved ... ;)
AlexanderPD
thank you for the fast response! :D
i changed the row2 color in stylesheet.css... purged cache.. but that color still don't change :|
aaaAaaAaa i really can't understand that D:
row1 & row3 are nearly the same colors... and they all are used on different blocks ;)
Try these two too...
AlexanderPD
Nothing too.. i tried to change all the "E4F4FE" in the stylesheet.css but that color doesn't change :\
And you surely cleared all your caches everytime? knowledge/kb_show.php?id=28
AlexanderPD
wah!! it works XD
i never purged the theme cache.. i always think that the main "purge cache" can purge all :P
thank you a lot! :D
