Your Portal Version: 1.02
Fresh Install
Tried adjusting CSS files.
I'm really struggling trying to figure out how to make the size of the portal fit the size of the background for Dark Fantasy. I've tried adjusting the settings in the stylesheet and portal.css, but nothing I change seems to have any effect. I'm happy to either make the background wider or the portal smaller. I think the issue may be on the right side of the portal as it looks too wide. I've also tried adjusting the pane sizes through the ACP, but that had no effect either. It is version 1.02 as the theme isn't done for 1.03 yet, but I'm assuming I should still be able to get it to work.
Thanks for your help.
Width of Portal
Re: Width of Portal
If you have enabled the Calendar, try to disable it. This Block is the main reason of such Problems...
Re: Width of Portal
That was it. Thanks for the help.
