Random Member issue
MrBaseball34
phpBB.de User: MB34
Random Member issue
Post by MrBaseball34 »
I modified the random_member block like I said in my replies to girlintrouble's question.
However, I don't want the block to show if there are no members returned from the query.
in random_member.php I made this change:
$member_count = $db->sql_affectedrows();
And this change:
if ($member_count > 0) {
  $template->assign_vars(array(
	  'S_DISPLAY_RANDOM_MEMBER' => true,
} else {
	  'S_DISPLAY_RANDOM_MEMBER' => false,
But I get no random members, even when I DO have some that opted in.
Any ideas why? If I remove the changes above, I get random members shown.[/i]
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
MrBaseball34
phpBB.de User: MB34
Re: Random Member issue
Oh, heck, nevermind. I was filtering by #posts, also and none of the members had enough posts.
MrBaseball34
Hook 'em Horns
