Can you share that block with everyone else?
"Tip for phpBB3 admins" Block
- phpBB.de User: MB34
MrBaseball34
Hook 'em Horns
![Image](http://www.delphicommunity.com/board/images/texas2.gif)
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
Re: "Tip for phpBB3 admins" Block
Its just the small custom Block adorned with an Image and a Link ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Can you post the php and html for that block. It is not clear how to build these custom blocks.
MrBaseball34
Hook 'em Horns
Hook 'em Horns
This is not a "builded" custom block, but the exisiting who is available via ACP.
If you want to make you own custom Block you should read this:
Knowledge Base: Adding Custom Blocks
