images in the portal?
hoffy
Hi again!
So far so good with the portal. Looks to be what I want, except for one thing....
Am I missing something, but I cannot display images on the portal page. I.E., from the news page, if I have anything betweeen the img tags, it wont display on the portal.
Is there a work around?
Thanks
Thanks
Re: images in the portal?
BBCodes are parsed in the normal (not compact) view of news and announcements boxes.
And [img] tags too. Maybe you have the news configured to cut the message after X-characters - and this cut is before or within the image tag (the bbcodes are counted too).
Try playing around with other (bigger) values for the maximum character settings.
hoffy
OK, I have tried that. Under both Global & news boxes, I have done the following:
Compact block = NO
max length = 0. I have also tried max length = 900
The image is also the first part of the post. Completely skips the image & goes straight to the thread.
Just another piece of info, not sure whether this will effect it, I have set the style to a maximum width.
cheers
Compact block = NO
cheers
hoffy
Another bit of info.
URL tags work fine.
B i & u tag works fine
List tag doesn't work
I don't have flash turned on, so can't check that one
URL tags work fine.
Do you have a testaccount? Link to the website?
hoffy
unfortunately, no. Its offline
hoffy
OK, I have found that if I use the basic prosilver style (un modded, except for board3 portal). It works fine
If I use my modded prosilver styles (one with a fixed width, the other without), there is a problem. I suppose, this is where the fun begins. I have no idea where to start, so these are the mods that have been done:
styles/<style>/themes/common.css
Mod to change to fixed width
Find:
Change to:
Find:
Change to:
Mod to remove header & replace just with logo
Find:
Change to:
Find:
Change to:
styles/<style>/themes/colours.css
Find:
Replace with:
Mod to include search function lower
Add below
styles/<style>/templates/overal_header.htm
Mod to remove search bar, as well as modify header background & logo
Find:
Replace with:
Mod to remove font size
Find & remove:
Mod to include search function lower:
Find:
Replace with:
I unfortunately, dont know where to start above. My styles are also colorizit styles
BTW, my live board (without the portal)is http://www.catchfencephotos.net
Find:
img {
border-width: 0;Code: Select all
img {
border-width: 0;
max-width: 100%;Find:
#wrap {
padding: 0 20px;
min-width: 650px;Code: Select all
#wrap {
padding: 0 20px;
min-width: 650px;
width: 1101px;
margin: 0 auto;Mod to remove header & replace just with logo
Find:
#logo {
float: left;
width: auto;
padding: 10px 13px 0 10px;
}Code: Select all
#logo {
float: center;
width: auto;
padding: 0px 0px 0 0px;
} Code: Select all
.headerbar {
background: #ebebeb none repeat-x 0 0;
color: #FFFFFF;
margin-bottom: 4px;
padding: 0 5px;
}Code: Select all
.headerbar {
}Mod to remove header & replace just with logo
Find:
.headerbar {
background-color: #263DD7;
background-image: url("{T_THEME_PATH}/images/bg_header.gif");
color: #FFFFFF;
}Code: Select all
.headerbar {
color: #FFFFFF;
}Code: Select all
Find:
.icon-faq { background-image: url("{T_THEME_PATH}/images/icon_faq.gif"); }Code: Select all
.icon-search { background-image: url("{T_THEME_PATH}/images/icon_textbox_search.gif"); }Mod to remove search bar, as well as modify header background & logo
Find:
<div id="site-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<div id="search-box">
<fieldset>
</fieldset>
</form>
<a href="{U_INDEX}" title="{L_INDEX}" id="logo">{SITE_LOGO_IMG}</a>Mod to remove font size
Find & remove:
<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li>Find:
<li class="icon-faq"><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li>Code: Select all
<!-- IF S_DISPLAY_SEARCH --><li class="icon-search"><a href="{U_SEARCH}" title="{L_SEARCH}">{L_SEARCH}</a></li><!-- ENDIF -->BTW, my live board (without the portal)is http://www.catchfencephotos.net
hoffy
Now I am lost. I started applying mods one at a time to my basic prosilver style & the first mod to change to a fixed width made the images disappear (see above for code changes)
The problem is, I also have a full width style, which includes all the other changes (as well as moving profile to the left). Unfortunately this doesnt display images on the portal either.
SO, I am thinking that there is more then one issue....or any changes to the style is effecting it. I would really like to get this fixed as I like the layout & this portal is much easier to deal with then some of the others.
I will play around some more tonight (I'm in Australia....its early morning!)
hoffy
OK, I have found out what is doing this. It is the change to the fixed board width that is causing the images to disappear. This was changed due to images being cropped when the page is being viewed on smaller resolution screens.
Does anyone know any way around this?
hoffy wrote:OK, I have found that if I use the basic prosilver style (un modded, except for board3 portal). It works fine
Find:Change to:Code: Select all
img { border-width: 0;Code: Select all
img { border-width: 0; max-width: 100%;
hoffy
Hi team!
Sorry to bump this, but does anyone know of a work around. I'm really keen to use this portal, but I want to maintain the Fixed width for photos.
Thanks
Thanks
wolferey
I usually mod the /includes/bbcode.php file, search for the <img src=" line, and add width="YOURWIDTH" so images have a fixed with, and then with an admin bbcode mod you can make so only admins have another img tag where you can set height and width yourself
hoffy
OK, thanks.
Is it possible to to set the width in this spot to 100% as opposed to specifying a number in Px? If I was to specify a fixed width, wouldn't it stretch images smaller then what is specified?
wolferey
I believe width="100%" should work. Not too sure thought, test it out and report back =)
hoffy
No problems. I will do when I get home from work!
hoffy
No, that didn't work. It resized the image to 100% of the space available. Not a good look! Same deal with the 800px, resized all images to 800px & it also didn't fix the issue where if the screen res is too small, the images are being cropped.
Back to the drawing board I suppose!
