Boardlink: http://www.lotro-latino.com/main/portal.php
PHP Version: 5.2.6
MySQL Version: 5.0.81
Hello there,
I've been trying phpBB3 and Board3 to set up a new website for my LOTRO guild, and I've run into a couple of problems I have no idea how to solve, mind you I'm kind of a beginner with all of this, so apologies in advance if my questions are too stupid :p
My website is: http://www.lotro-latino.com/main/portal.php
As you can see, I have the DVGFX2 style for phpbb3 and the B3P_DVGFX2 style for the portal. Everything is working great, but I want to do a couple of things:
1. Put the background color black, so the white bar at the end doesn't display. I want it black, so the lower black part of the image integrates with the black background
2. Stretch the entire portal/forum main table. I love this style, but I don't like the width of the "main" table at the moment, I want it a bit wider so you can't see the black center of the background image.
3. Remove the SiteLogo table, so the portal/forum begins at a certain position.
What I would like to achieve explained in a picture:
http://farm3.static.flickr.com/2478/370 ... edc2_b.jpg
I don't need every single modification, sizes, etc. I just need pointers as to what files/lines to modify, so I can edit/test/edit/test, until I reach the widths/positions I want.
Thank you very much in advance
