Upgraded to 1.0.3 but still says v1.0.2
thepips
phpBB.com User: thepips
Post by thepips »
Your Portal Version: 1.0.3
Was running v1.0.2 and installed v1.0.3 as per \contrib\update_board3portal_102.xml
Restored from backup and tried again
I've upgraded the portal on my development system but it still says 1.0.2 in the ACP. I've checked all of the changes described in \contrib\update_board3portal_102.xml very carefully but I can't find what I've missed. Is there a quick fix?
Regards
Doug
Re: Upgraded to 1.0.3 but still says v1.0.2
Did you run the installer and click on update?
thepips
Post by thepips »
I restored my backup version and reinstalled everything again, carefully, and this time it worked. I can only assume I missed a step last time.
Thanks for your help
Doug
