Boardlink: n/a
n/a
n/a
Hello, I went and set up portal, but I got to the part we're its diy and it says run the installer, the only problem is there is around 10 installers which one is the one that need to be ran?
Install
Re: Install
There is only one.
After uploading the complete content of the root directory (contained in the B3P package) to your forum root directory, you have to browse to the installer. e.g:
www.yourdomain.com/phpbb/install/install.php
Re: Install
Um I tried that, but the install.php leads to a blank white page when I try to link to it
the link I was using was fortheemperor.com/testring/install/install.php which should be right but I can get it to show up.
Re: Install
Yes, Mike is correct.
Sorry, my bad. The install.php was the old way.
Re: Install
I am struggling to hell trying to get this portal to work.... Can anyone help me.... I will buy a copy of the phpbb v3 off anyone that has it pre installed
