Problem with IExplorer
luishem
Post by luishem »
Boardlink: http://clubgauss.net.tc/
Nothing
Researching
The right bar mixes with the central bar. :(
This happens only with IExplorer, ive cheked it in other 4 computers and the problem persists. :?
With firefox the site shows great. :)
Please help! :!:
Re: Problem with IExplorer
Since i have this error too, but only on your Board, and not on mine or at this Board, you probably make an mistake if you installed Portal.
Maybe you changed any css files, or you have an error in your footer since you added the adverts. If i can see, some right blocks doesnt have a frame (calendar e.g.).
Try to check the install.xml step by step. Essentially the part for the prosilver template.
If im right, you have made an error there ;)
luishem
Post by luishem »
solved, i think. I turned of the links section, though, :|
now the problem is
Try this:
open: styles/prosilver/template/portal/block/search.html
find:
 <select id="qsearch_select" tabindex="7">
replace with:
<select style="width: 140px;" id="qsearch_select" tabindex="7">
luishem
Post by luishem »
I did it and it went bad
No... if i visit your site with IE, the search Block seems to be ok now.
But if you want to add thousands of adverts in all of your blocks, you dont have to wonder why you always crash your layout.
You can't add an ad in the middle of the calendar :roll:
Maybe you should learn any Basics about html and css ;)
luishem
Post by luishem »
Fixed.
Lol :D , it isnt me adding the ads.
What happens is im using a free hosting service, and everytime i start editing a template file, the server writes the ad`s code right at the bottom of it :lol:
Thanks any way, the code to adjust width was very helpful :P
luishem wrote:everytime i start editing a template file, the server writes the ad`s code right at the bottom of it :lol:
This is one of the reasons why Free Hosting Services are Bullshit. It costs less than €10 per Month to have a commercial-free webspace with al you need inclusive...
Anyway, if it works now its going for Green ;)
