Your Portal Version: 1.0.3RC3
Boardlink: http://www.crazyforgaming.co.uk
Installed a fresh version of PhPbb onto the server then installed the portal
Searched through the header html to see if there is a problem but i dont see any. All the suggested code changes had been changed before the installation was done.
After I ran the installation everything sempt to install correctly without any error messeges however when i entered the ACP and cleared the cache on the templates and on the main board I returned to the main forum board and i have no option in the nav bar at the top for the portal. Also when i refresh the page it doestnt root me to the portal as the home page and if i try to navigate there through my browser I just get a blank page. Please help.
No Portal in nav bar and blank pages
Re: No Portal in nav bar and blank pages
I tried to re-install the portal and i now get this messege for the portal page not found.
The link to the portal page is http://75.125.60.11/~crazyfor/portal.ph ... 63196f452c
This is a clear server message - the file does not exist.404 - Not Found
Follow the tips that are displayed.
This issue is solved thankyou, I had a database problem that rectified itself when i repaired the database. Thankyou.
