No Portal Link - just Board Index
Blades
phpBB.de User: Blades
phpBB.com User: Blades1000
Post by Blades »
Your Portal Version: 1.0.2
Boardlink: http://www.australianinvestigators.com/ ... portal.php
PHP Version: 3.0.4
Nothing, the problem was there right after the install.
Tried re-doing the 610nm style edits to make sure they were correct. Some code missing from my files.
First off, awesome mod :D
I installed the standard version and got that working fine with Prosilver. My board uses the 610nm style, so I downloaded the zip from this board and followed the install instructions. Everything works fine, except there is no link to the portal from within the forum (at the top in the header bar). If you just go to the main folder www.australianinvestigators.com/phpBB3 you get the portal, but that is the only way using the 610nm style.
When doing the upgrade, the last step of the edits on styles/610nm/template/overall_header.html, I couldn't match the text, as mine was a little different. This is a copy of what I currently have (which I just put the edit in at the bottom):
<head>
{META}
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
<!-- // MOD : MSSTI ABBC3 (V1.0.11) - Start -->
<!-- IF S_ABBC3_MOD and ( S_BBCODE_ALLOWED or S_NEW_MESSAGE or S_EDIT_POST or S_VIEWTOPIC or S_DISPLAY_PREVIEW or S_POST_REVIEW or S_DISPLAY_REVIEW ) or ( U_MCP and ( U_MCP_POST or U_MCP_TOPIC or U_MCP_FORUM) ) or ( S_PRIVMSGS and S_VIEW_MESSAGE ) -->
<script type="text/javascript" src="{S_ABBC3_PATH}/abbcode.js" charset="{S_CONTENT_ENCODING}"></script>
<link rel="stylesheet" type="text/css" media="all" href="{S_ABBC3_PATH}/abbcode.css" />
<!-- IF S_ABBC3_RESIZE -->
<script type="text/javascript" src="{S_ABBC3_PATH}/AdvancedBox.js"></script>
// <![CDATA[
/** Image Resizer JS and AdvancedBox JS - Start **/
	var ImageResizerNumberOf			= '{L_ABBC3_RESIZE_NUMBER}';
	var ImageResizerNextAlt				= '{L_NEXT}';
	var ImageResizerPrevtAlt			= '{L_PREVIOUS}';
	var ImageResizerPlayAlt				= '{L_ABBC3_RESIZE_PLAY}';
	var ImageResizerPauseAlt			= '{L_ABBC3_RESIZE_PAUSE}';
	var ImageResizerZoomInAlt			= '{L_ABBC3_RESIZE_ZOOM_IN}';
	var ImageResizerZoomOutAlt			= '{L_ABBC3_RESIZE_ZOOM_OUT}';
	var ImageResizerCloseAlt			= '{L_ABBC3_RESIZE_CLOSE}';
	var ImageResizerBlankImage			= '{S_ABBC3_PATH}/advancedbox_blank.gif';
	var ImageResizerSignature			= '{S_ABBC3_RESIZE_SIGNATURE}';
	var ImageResizerMode				= '{S_ABBC3_RESIZE_METHOD}'; // 'advancedbox' 'pop-up' 'enlarge' 'samewindow' 'newwindow'
	var ImageResizerWarningImage		= '{S_ABBC3_PATH}/warning.gif';
	var ImageResizerMaxWidth			= '{S_ABBC3_MAX_IMG_WIDTH}' ;
	var ImageResizerMaxHeight			= '{S_ABBC3_MAX_IMG_HEIGHT}' ;
	var ImageResizerWarningSmall		= '{L_ABBC3_RESIZE_SMALL}';
	var ImageResizerWarningFullsize		= '{L_ABBC3_RESIZE_FULLSIZE}';
	var ImageResizerWarningFilesize		= '{L_ABBC3_RESIZE_FILESIZE}';
	var ImageResizerWarningNoFilesize	= '{L_ABBC3_RESIZE_NOFILESIZE}';
/** Image Resizer JS and AdvancedBox JS - End **/
</script>
<!-- // MOD : MSSTI ABBC3 (V1.0.11) - End -->
</head>
<div id="wrap">
<a href="#" onclick="fontsizeup(); return false;" onkeypress="fontsizeup(); return false;" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a>
<div id="topnav">
	<div id="search-box">
		<fieldset>
			<input name="keywords" id="keywords" type="text" title="{L_SEARCH_KEYWORDS}" class="inputbox search" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" />
			{S_SEARCH_HIDDEN_FIELDS}
		</fieldset>
		</form>
<div class="b"><div class="bl"><div class="br">
	<div id="header_container">
		<div id="header_bg">
	<div id="wrapheader">
		<div id="navcontainer">
			<ul id="navlist">
			<li><a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a>
			<!-- IF S_DISPLAY_PM --><li><a href="{U_PRIVATEMSGS}">({PRIVATE_MESSAGE_INFO})</a></li><!-- ENDIF -->
			<!-- IF U_RESTORE_PERMISSIONS --><li><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a></li><!-- ENDIF -->
			<li><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li>
			<!-- IF not S_IS_BOT --><!-- IF S_DISPLAY_MEMBERLIST --><li><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
			<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
			<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li><!-- ENDIF -->
			<!-- IF S_DISPLAY_SEARCH --><li><a href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}">{L_SEARCH}</a></li><!-- ENDIF -->
		<div id="datebar">
	<div id="wrapcentre">
If anyone can show me what I need to change so that I can have a link to the Portal, like in the Prosilver version, that would be great. I was going to upgrade to 1.0.3 in the hopes that would fix the problem, but haven't been able to find anything about the 610nm version being updated to work.
Thanks in advance :)[/i]
Re: No Portal Link - just Board Index
The 610nm Style is based on subsilver2 and not prosilver. Follow the instructions as described in subsilver2.xml ;)
The Link has to be added in breadcrumbs.html...
