I was hoping to put something on the front page (particularly in the menu if possible) that will display the users IP address. I can't seem to find a simple way to do this. It would just be
your IP is: 235.234.23.123
IP address?
Re: IP address?
Code could be easily found with google. e.g. http://php.about.com/od/learnphp/p/what_my_ip.htm
Just search for "my ip script".
If you dont get along to implement it into the portal, just let me know.
- phpBB.com User: dudenell
Re: IP address?
alright well I had someone help me out with this, its for subsilver2, I'm sure it wont be hard to figure it out for prosilver
open portal.php
after add:
save the file and upload
Then open *your directory*/styles/subsilver2/template/portal/block/main_menu.html
find
after add
clear the cache and you should have a display.
open portal.php
$load_center = true;
$template->assign_vars(array('USERIP' => $_SERVER['REMOTE_ADDR']));
find
<tr class="row1">
<td>
<a href="{U_TEAM}">{L_THE_TEAM}</a>
<tr class="row1">
<td>
Your IP: {USERIP}</a>
