Boardlink: http://crizzo-designs.com
PHP Version: 5.2.4
MySQL Version: 5.0.67
Just installed the portal
nothing not sure how to fix, I do have a MOD Ranks_per_groups_v1.0.1 I am thinking it has something to do with this just by errors but not sure what I need to do to fix? I had this installed before the portal and it was working fine.
I am getting this error when I load portal (front page):
When I go to mysite/index.php the forums shows fine only when I try to navigate to portal page!
General Error
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') ORDER BY r.rank_min DESC' at line 1 [1064]
SQL
SELECT r.*, gr.group_rank_title, gr.group_rank_image FROM (phpbb_ranks r) LEFT JOIN phpbb_groups_ranks gr ON (gr.rank_id = r.rank_id AND gr.group_id = ) ORDER BY r.rank_min DESC
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
FILE: includes/cache.php
LINE: 152
CALL: dbal_mysql->sql_query()
FILE: includes/functions_display.php
LINE: 1160
CALL: cache->obtain_ranks()
FILE: portal/block/user_menu.php
LINE: 79
CALL: get_user_rank()
FILE: portal.php
LINE: 137
CALL: include('portal/block/user_menu.php')
Christopher[/i]
