Using Paron style
joannemojo
phpBB.com User: joannemojo
Using Paron style
Post by joannemojo »
Boardlink: http://www.tintedwindowsfan.com/forum
Just used style other than subsilver2 etc.
This is my first attempt at installing the portal. Everything was going fine until I got to the part where you have to edit overall_header.html.
I am using the style Paron. Could anyone help me with what I need to do to edit the overall_header.html and overall_footer.html as they don't match what's said in the instructions.
You can see the style in action @ http://www.tintedwindowsfan.com/forum but I am testing this all out @ http://www.tintedwindowsfan.com/test_forum
Thanks.
joannemojo
Re: Using Paron style
I installed using prosilver and now when I try to access the site I get:
template->_tpl_load_file(): File ./styles/prosilver/template//portal/portal_body.html does not exist or is empty
LaYxOn
phpBB.de User: LaYxOn
phpBB.com User: LaYxOn
Post by LaYxOn »
i have the same problema, i installed the style Gateway and i get that error :cry:
General Error
template->_tpl_load_file(): File ./styles/getaway/template//portal/portal_body.html does not exist or is empty
I tried the style modifitacion on the knowledge base section, but when it says purge the cache on the ACP i don´t have that option, i only can do the first part of the manual
any solution?
Thanks
Looks like you dont uploaded the files for your styles from our downloadpackage. If your style is based on prosilver, you have to copy the prosilver files into your styles folder. And the same for subsilver2 based Styles. Then you have the requested files ;)
