Komme nach Update nicht mehr ins ACP :-(
TeddyT
Post by TeddyT »
Hallo zusammen,
das Update scheint auf den ersten Blick funktioniert zu haben und man kann sich auch einloggen.
Doch wenn ich auf ACP Login klick erscheint bereits die erste Fehlermeldung:
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3397: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3399: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3400: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3401: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
Wenn ich dann auf Login klicke, werde ich automatisch ausgeloggt und es erscheint folgende Meldung:
[phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
[phpBB Debug] PHP Notice: in file /includes/session.php on line 1591: Cannot modify header information - headers already sent by (output started at /adm/index.php:1)
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/w0089175/board/adm/index.php:1) in /www/htdocs/w0089175/board/includes/functions.php on line 3397
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/w0089175/board/adm/index.php:1) in /www/htdocs/w0089175/board/includes/functions.php on line 3399
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/w0089175/board/adm/index.php:1) in /www/htdocs/w0089175/board/includes/functions.php on line 3400
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/w0089175/board/adm/index.php:1) in /www/htdocs/w0089175/board/includes/functions.php on line 3401
Re: Komme nach Update nicht mehr ins ACP :-(
Da scheint was bei der Editierung der adm/index.php schief gegangen zu sein.
Lade die Originale noch mal hoch, teste, dann editier noch mal.
TeddyT
Post by TeddyT »
habe jetzt noch mal die originale index.php aus PHPBB 3.0 installiert und das ACP funktioniert.
Sobald ich aber Euren neuen Code einfüge "$user->add_lang('mods/lang_portal_acp_logs');" geht es wieder nicht mehr :cry:
Dann hast du wahrscheinlich nicht die lang_portal_acp_logs.php aus \languages\de\mods\ in \language\de\mods\ geladen.
Überprüfe bitte ob du wirklich alle Dateien hochgeladen / aktualisiert hast.
Verlinke ansonsten bitte, sollten die Probleme weiter bestehen, die adm/index.php, so wie du sie editiert hast, hier als Textdatei.
TeddyT
Post by TeddyT »
Problem gelöst.
Die Datein waren alle da. Bisher habe ich Dateien immer mit Ultraedit bearbeitet was aber diesmal nicht so richtig funktioniert hat, wahrscheinlich wegen der UTF-8 Formatierung. Nachdem ich die Datei jetzt mit Notepad++ bearbeitet habe, geht es :?
Besten Dank für Eure Hilfe ;)
