Boardlink: http://prikbord.ilovebrasil.com/forum/portal.php
Where should I change the colors? In portal.css? But which line is for which color?
Rudolf.
How to change the colors of the portal menu?
Re: How to change the colors of the portal menu?
where you want to change???
I want to change the colors of the portal menu on the left. (all the colors they don't fit with the site's color).japagun wrote:where you want to change???
You can check it here: http://prikbord.ilovebrasil.com/forum/portal.php
Rudolf.
Can anybody give me some tips or links where this is explained?rudolfpietersma wrote:I want to change the colors of the portal menu on the left. (all the colors they don't fit with the site's color).japagun wrote:where you want to change???
Rudolf.
Check your portal.css (styles/prosilver/theme/portal.css) for the following line:
Beneath you will find all navigation-related css... (colors too )
/*Portal-menu*/
