Your Portal Version: 1.0.2
Boardlink: http://DIYaquaponics.com/forum/
Running phpBB3.04 with board3 Portal with AeroBlue
Looked at forum...couldn't find anthing...looked at files...didn't have any idea which ones to look at.
I would like to be able to move some of the boxes from the left side menu to the right and some from the right to the left side. Can you please tell me which file or files control that and what I need to do to accomplish that?
Thanks for any help you can give
Codi
Moving side menu items
Re: Moving side menu items
If you look in the portal_body.html file, you will see all the blocks being included there, you have a left, center and a right hand side for blocks. You can simply cut and paste the include statement from left to right and vice versa.
- phpBB.de User: Christian_N
- phpBB.com User: Christian_N
Please also read the board rule, and note: viewtopic.php?f=8&t=1641
KB: Moving blocks / change order
Thanks.
- Asking questions
- Search function / Knowledge Base Please use the Search function and search the Knowledge Base / FAQ prior to post a question. Most questions have already been asked. And almost all of them have already been answered.
