Boardlink: http://www.talkyork.com
Hello
i am a very basic user of php and have just set up a community website for my town. i want to ask some questions about board 3:
1) i am using the proformell style for my site. if i install board 3 will it be displayed in this style?
2) can i edit the board 3 style to just use the bits i need. What i want is just a user menu down the left side of the screen. i want the centre and right side to be for the forum.
3) how difficult is the adding of this portal to my site. do i need to understand coding?
using board 3
Re: using board 3
1 yes....try to do in localhost
2 yes if you understand a little of html codes
3 its very easy do to this changes....
