Your Portal Version: 1.0.2 ENG
Boardlink: http://phoenixgaminguk.com/portal.php
Nothing
OK Guys, sorry if I seem a bit thick, not been using phpBB much yet. I am a IT Engineer working in the UK and when I decided to redesign my site I was recommended to use phpBB 3 with Board3 as the front end.
OK, I thought, no problem, got it all installed fine, even customized it some, quite easy this is, damn good job by the guys who created it.
Anyhow, the problem is this, I have downloaded 2 new skins/themes from the board3 themes site (acidtech_tiger & black_pearl), I have unpacked them into the correct directory according to the instructions (/root/styles), that's fine. However they won't appear in the styles list in the control panel, OK I thought, opened up the xml instruction file which each theme, found the section for which files to edit, only thing is the files I need to edit are not there. I have the directory's inside but the particular files it says to edit are missing, they are not in the zip archive either. For example inside black_pearl I have folders labelled template & theme, inside template is a folder labelled portal but no files, inside portal is a folder labelled block, a file labelled index.html and a file labelled portal_body.html, inside block is a lot of files. None of these are the ones the instructions refer me to edit.
What am I doing wrong, both myself and my mate have had a look at it, my mate is the one who referred me, however whilst his site works perfect, he set it up that long ago he can't remeber what he did to make it work on his.
Hope this makes sense to any of you, I could really use the help.
Help - Style not installed - Newbie Alert!
ThePhoenix
Re: Help - Style not installed - Newbie Alert!
i am not totally sure- but could it be that you only downloaded the styles for the portal and that the basic styles are not there. Here is an overview about the content of the black pearl style (sorry for the German output - bu i think you know what it is):
So first get the style installed and then you could add the portal style (folders) as well. And then it should work...
Volume in Laufwerk C: hat keine Bezeichnung.
Volumeseriennummer: 001D-1F68
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl
10.02.2009 22:54 <DIR> .
10.02.2009 22:54 <DIR> ..
10.02.2009 22:53 652 black_pearl.txt
23.11.2008 20:25 <DIR> contrib
23.11.2008 20:46 <DIR> imageset
16.11.2008 09:54 645 style.cfg
23.11.2008 20:44 <DIR> template
10.02.2009 22:54 0 test.txt
23.11.2008 20:35 <DIR> theme
3 Datei(en) 1.297 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\contrib
23.11.2008 20:25 <DIR> .
23.11.2008 20:25 <DIR> ..
23.11.2008 20:25 <DIR> css
23.11.2008 20:48 <DIR> gdk
26.08.2008 20:34 2.624 readme.txt
23.11.2008 20:25 <DIR> template
1 Datei(en) 2.624 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\contrib\css
16.01.2008 23:01 17.426 stylesheet_old.css
1 Datei(en) 17.426 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\contrib\gdk
23.11.2008 20:48 <DIR> .
23.11.2008 20:48 <DIR> ..
17.09.2007 19:51 1.000.429 BLACK_PEARL_ENG_BB3_LITE_20070917.psd
15.09.2007 20:18 7.751 black_pearl_orb_empty.png
2 Datei(en) 1.008.180 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\contrib\template
05.01.2008 12:05 16.301 viewtopic_body_pr.html
08.04.2008 00:03 3.382 _forumlist_body.html
25.08.2007 11:27 4.605 _index_body.html
15.04.2008 12:01 1.711 _menu_block_old.html
08.04.2008 00:07 16.987 _posting_body.html
08.04.2008 00:26 16.189 _viewtopic_body_left.html
08.04.2008 00:26 16.190 _viewtopic_body_right.html
7 Datei(en) 75.365 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\imageset
23.11.2008 20:46 <DIR> .
23.11.2008 20:46 <DIR> ..
17.08.2007 10:43 724 announce_global_read.png
17.08.2007 10:43 844 announce_global_read_locked.png
17.08.2007 10:43 938 announce_global_read_locked_mine.png
17.08.2007 10:43 827 announce_global_read_mine.png
17.08.2007 10:43 731 announce_global_unread.png
17.08.2007 10:43 846 announce_global_unread_locked.png
17.08.2007 10:43 936 announce_global_unread_locked_mine.png
17.08.2007 10:43 823 announce_global_unread_mine.png
17.08.2007 10:43 759 announce_read.png
17.08.2007 10:43 861 announce_read_locked.png
17.08.2007 10:43 948 announce_read_locked_mine.png
17.08.2007 10:43 857 announce_read_mine.png
17.08.2007 10:43 753 announce_unread.png
17.08.2007 10:43 860 announce_unread_locked.png
17.08.2007 10:43 948 announce_unread_locked_mine.png
17.08.2007 10:43 854 announce_unread_mine.png
17.08.2007 10:43 708 arrow_down.png
17.08.2007 10:43 704 arrow_left.png
17.08.2007 10:43 705 arrow_right.png
17.08.2007 10:43 699 arrow_up.png
23.11.2008 20:46 <DIR> en
16.10.2007 22:10 1.233 forum_ar.png
16.10.2007 22:10 1.051 forum_link.png
16.10.2007 22:10 1.126 forum_read.png
16.10.2007 22:10 1.329 forum_read_locked.png
17.08.2007 10:43 1.257 forum_read_subforum.png
16.10.2007 22:10 1.354 forum_sub_ar.png
16.10.2007 22:10 1.146 forum_unread.png
17.08.2007 10:43 1.289 forum_unread_locked.png
16.10.2007 22:10 1.197 forum_unread_subforum.png
17.08.2007 10:43 816 icon_contact_s_aim.png
17.08.2007 10:43 1.006 icon_contact_s_icq.png
17.08.2007 10:43 816 icon_contact_s_jabber.png
17.08.2007 10:43 760 icon_contact_s_msnm.png
17.08.2007 10:43 992 icon_contact_s_skype.png
17.08.2007 10:43 505 icon_contact_s_yahoo.png
17.08.2007 10:43 292 icon_maximize.png
17.08.2007 10:43 261 icon_minimize.png
17.08.2007 12:03 859 icon_post_target.gif
16.10.2007 22:28 270 icon_post_target_unread.gif
02.08.2007 18:03 597 icon_topic_attach.gif
17.08.2007 12:03 907 icon_topic_latest.gif
16.10.2007 22:28 311 icon_topic_newest.gif
17.08.2007 10:43 742 icon_topic_reported.png
17.08.2007 10:43 695 icon_topic_unapproved.png
17.08.2007 10:43 706 icon_user_s_hidden.png
17.08.2007 10:43 849 icon_user_s_ip.png
17.08.2007 10:43 914 icon_user_s_offline.png
17.08.2007 10:43 926 icon_user_s_online.png
16.11.2008 09:54 3.846 imageset.cfg
17.08.2007 10:43 695 important_read.png
17.08.2007 10:43 795 important_read_locked.png
17.08.2007 10:43 887 important_read_locked_mine.png
17.08.2007 10:43 783 important_read_mine.png
17.08.2007 10:43 680 important_unread.png
17.08.2007 10:43 791 important_unread_locked.png
17.08.2007 10:43 882 important_unread_locked_mine.png
17.08.2007 10:43 767 important_unread_mine.png
17.08.2007 10:43 709 locked_read.png
17.08.2007 10:43 809 locked_read_mine.png
17.08.2007 10:43 711 locked_unread.png
17.08.2007 10:43 807 locked_unread_mine.png
17.08.2007 12:13 819 poll_center.gif
17.08.2007 12:13 869 poll_left.gif
17.08.2007 12:14 866 poll_right.gif
30.08.2006 12:23 760 post_asterisk.png
12.03.2006 20:49 593 post_book.png
14.02.2006 13:14 588 post_email.png
12.03.2006 20:52 701 post_exclamation.png
12.03.2006 20:53 778 post_information.png
12.03.2006 20:54 378 post_new.png
14.02.2006 13:14 584 post_next.png
12.03.2006 20:55 879 post_page_find.png
14.02.2006 13:14 617 post_previous.png
14.02.2006 13:14 702 post_print.png
05.09.2006 22:35 666 post_warning.png
26.06.2007 13:06 13.194 sitelogo_small.png
17.08.2007 10:43 722 topic_moved.png
17.08.2007 10:43 624 topic_read.png
17.08.2007 10:43 706 topic_read_hot.png
17.08.2007 10:43 837 topic_read_hot_locked.png
17.08.2007 10:43 912 topic_read_hot_locked_mine.png
17.08.2007 10:43 803 topic_read_hot_mine.png
17.08.2007 10:43 774 topic_read_locked.png
17.08.2007 10:43 872 topic_read_locked_mine.png
17.08.2007 10:43 752 topic_read_mine.png
17.08.2007 10:43 621 topic_unread.png
17.08.2007 10:43 715 topic_unread_hot.png
17.08.2007 10:43 838 topic_unread_hot_locked.png
17.08.2007 10:43 925 topic_unread_hot_locked_mine.png
17.08.2007 10:43 816 topic_unread_hot_mine.png
17.08.2007 10:43 772 topic_unread_locked.png
17.08.2007 10:43 872 topic_unread_locked_mine.png
17.08.2007 10:43 740 topic_unread_mine.png
02.04.2007 00:45 12.892 upload_bar.gif
94 Datei(en) 102.880 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\imageset\en
17.08.2007 10:43 1.055 button_pm_new.png
17.08.2007 10:43 1.013 button_pm_reply.png
17.08.2007 10:43 687 button_pm_s_reply.png
17.08.2007 10:43 955 button_topic_locked.png
17.08.2007 10:43 1.096 button_topic_new.png
17.08.2007 10:43 1.078 button_topic_reply.png
17.08.2007 10:43 744 icon_contact_aim.png
17.08.2007 10:43 676 icon_contact_email.png
17.08.2007 10:43 617 icon_contact_icq.png
17.08.2007 10:43 717 icon_contact_jabber.png
17.08.2007 10:43 785 icon_contact_msnm.png
17.08.2007 10:43 582 icon_contact_pm.png
17.08.2007 10:43 701 icon_contact_skype.png
17.08.2007 10:43 797 icon_contact_www.png
17.08.2007 10:43 662 icon_contact_yahoo.png
17.08.2007 10:43 658 icon_post_delete.png
17.08.2007 10:43 634 icon_post_edit.png
17.08.2007 10:43 759 icon_post_info.png
17.08.2007 10:43 699 icon_post_quote.png
17.08.2007 10:43 731 icon_post_report.png
17.08.2007 10:43 772 icon_user_hidden.png
17.08.2007 10:43 487 icon_user_ip.png
17.08.2007 10:43 855 icon_user_offline.png
17.08.2007 10:43 882 icon_user_online.png
17.08.2007 10:43 879 icon_user_profile.png
17.08.2007 10:43 766 icon_user_search.png
17.08.2007 10:43 695 icon_user_warn.png
17.08.2007 12:25 1.597 imageset.cfg
28 Datei(en) 22.579 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\template
23.11.2008 20:44 <DIR> .
23.11.2008 20:44 <DIR> ..
05.12.2007 21:43 6.073 attachment.html
05.12.2007 21:43 2.755 bbcode.html
23.11.2008 20:44 872 breadcrumbs.html
23.11.2008 20:44 513 breadcrumbs_footer.html
23.11.2008 20:43 829 breadcrumbs_pages.html
07.08.2007 00:18 1.007 confirm_body.html
08.07.2007 20:43 1.590 custom_profile_fields.html
05.12.2007 21:44 8.928 editor.js
15.11.2008 10:06 2.072 faq_body.html
15.11.2008 10:08 5.288 forumlist_body.html
06.08.2007 11:33 508 index.htm
23.11.2008 20:43 8.088 index_body.html
07.08.2007 01:28 978 jumpbox.html
07.04.2008 23:51 4.110 login_body.html
16.10.2007 00:41 1.395 login_forum.html
16.10.2007 00:41 2.122 mcp_approve.html
15.11.2008 10:14 4.600 mcp_ban.html
07.08.2007 00:29 746 mcp_footer.html
15.11.2008 10:22 4.656 mcp_forum.html
15.11.2008 10:23 6.374 mcp_front.html
07.08.2007 00:29 3.534 mcp_header.html
16.10.2007 00:45 923 mcp_jumpbox.html
16.10.2007 00:45 2.099 mcp_logs.html
06.08.2007 16:36 538 mcp_message.html
16.10.2007 00:48 1.646 mcp_move.html
16.10.2007 00:48 967 mcp_notes_front.html
16.10.2007 00:48 4.715 mcp_notes_user.html
15.11.2008 10:25 10.195 mcp_post.html
16.10.2007 00:49 3.042 mcp_queue.html
16.10.2007 00:50 3.289 mcp_reports.html
16.10.2007 00:50 7.506 mcp_topic.html
16.10.2007 00:51 2.557 mcp_viewlogs.html
16.10.2007 00:51 3.214 mcp_warn_front.html
16.10.2007 00:51 1.783 mcp_warn_list.html
15.11.2008 10:26 2.202 mcp_warn_post.html
15.11.2008 10:26 2.685 mcp_warn_user.html
06.08.2007 16:16 548 mcp_whois.html
16.10.2007 00:55 6.004 memberlist_body.html
16.10.2007 00:56 2.606 memberlist_email.html
01.11.2007 21:40 1.139 memberlist_group.html
16.10.2007 00:58 4.132 memberlist_im.html
07.08.2007 01:51 3.108 memberlist_leaders.html
07.04.2008 23:54 4.844 memberlist_search.html
23.11.2008 20:41 9.364 memberlist_view.html
23.11.2008 20:41 2.012 menu_block.html
07.08.2007 01:31 624 message_body.html
26.08.2008 20:39 1.785 overall_footer.html
23.11.2008 20:40 6.213 overall_header.html
08.07.2007 20:43 313 pagination.html
03.11.2006 15:16 1.293 pngfix.js
16.10.2007 10:20 2.306 posting_attach_body.html
11.07.2008 15:40 16.768 posting_body.html
05.12.2007 21:45 5.046 posting_buttons.html
09.08.2007 10:13 1.706 posting_poll_body.html
28.11.2007 13:15 2.279 posting_preview.html
16.10.2007 10:21 1.005 posting_progress_bar.html
17.08.2007 13:21 3.232 posting_review.html
16.10.2007 10:22 955 posting_smilies.html
17.08.2007 13:21 3.834 posting_topic_review.html
16.10.2007 10:22 2.110 report_body.html
25.08.2007 01:48 3.975 scripts.js
08.07.2007 20:43 233 searchbox.html
05.12.2007 21:46 5.035 search_body.html
11.07.2008 11:39 7.476 search_results.html
09.08.2007 15:08 689 simple_footer.html
08.04.2008 00:09 1.148 simple_header.html
16.11.2008 09:54 652 template.cfg
08.04.2008 00:11 2.095 ucp_agreement.html
09.08.2007 11:12 3.529 ucp_attachments.html
05.12.2007 21:46 368 ucp_footer.html
15.11.2008 10:28 11.566 ucp_groups_manage.html
09.08.2007 11:19 5.183 ucp_groups_membership.html
16.10.2007 10:29 6.736 ucp_header.html
09.08.2007 12:20 3.369 ucp_main_bookmarks.html
16.10.2007 10:32 3.921 ucp_main_drafts.html
09.08.2007 12:23 3.180 ucp_main_front.html
15.11.2008 10:30 4.186 ucp_main_subscribed.html
15.11.2008 10:31 3.319 ucp_pm_history.html
16.10.2007 10:33 2.448 ucp_pm_message_footer.html
16.10.2007 10:33 1.626 ucp_pm_message_header.html
16.10.2007 10:34 10.889 ucp_pm_options.html
16.10.2007 10:34 1.093 ucp_pm_popup.html
16.10.2007 10:35 5.025 ucp_pm_viewfolder.html
16.10.2007 10:37 4.297 ucp_pm_viewmessage.html
09.08.2007 10:55 3.348 ucp_pm_viewmessage_print.html
16.10.2007 10:38 6.260 ucp_prefs_personal.html
09.08.2007 10:56 2.378 ucp_prefs_post.html
17.08.2007 13:21 4.295 ucp_prefs_view.html
09.08.2007 11:00 4.257 ucp_profile_avatar.html
09.08.2007 11:00 3.577 ucp_profile_profile_info.html
09.08.2007 11:01 2.775 ucp_profile_reg_details.html
16.10.2007 10:38 3.187 ucp_profile_signature.html
08.04.2008 00:12 3.993 ucp_register.html
16.10.2007 10:41 1.179 ucp_remind.html
08.04.2008 00:14 1.176 ucp_resend.html
16.10.2007 10:41 1.516 ucp_zebra_foes.html
16.10.2007 10:42 1.519 ucp_zebra_friends.html
15.11.2008 10:33 14.005 viewforum_body.html
16.10.2007 10:51 3.011 viewonline_body.html
16.10.2007 10:53 530 viewonline_whois.html
23.11.2008 20:36 16.641 viewtopic_body.html
07.08.2007 18:26 3.328 viewtopic_print.html
23.11.2008 20:44 973 _mg_config.html
103 Datei(en) 367.611 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\theme
23.11.2008 20:35 <DIR> .
23.11.2008 20:35 <DIR> ..
03.05.2007 01:06 5.467 fap.css
23.11.2008 20:47 <DIR> images
23.11.2008 20:48 21.169 stylesheet.css
16.11.2008 09:54 980 theme.cfg
3 Datei(en) 27.616 Bytes
Verzeichnis von .\phpbb3_black_pearl_1_4_5\black_pearl\theme\images
23.11.2008 20:47 <DIR> .
23.11.2008 20:47 <DIR> ..
09.08.2007 10:04 666 bbc_code.gif
09.08.2007 10:10 616 bbc_quote.gif
09.08.2007 10:06 637 bbc_zip.gif
07.06.2007 01:49 399 bg_body.gif
08.06.2007 01:33 1.069 bg_buttons.gif
07.06.2007 01:48 824 bg_catbottom.gif
07.06.2007 20:44 86 bg_code_header.gif
07.06.2007 01:47 76 bg_copyright.gif
08.06.2007 16:28 80 bg_footer.gif
08.06.2007 16:28 80 bg_hdr.gif
07.06.2007 01:45 102 bg_hdr1.gif
07.06.2007 02:01 125 bg_input.gif
08.06.2007 02:08 95 bg_nav1.gif
07.06.2007 02:02 217 bg_nav2.gif
07.06.2007 01:43 425 bg_post.gif
07.06.2007 01:43 144 bg_postbottom.gif
07.06.2007 20:43 204 bg_quote_content.gif
07.06.2007 20:42 199 bg_quote_header.gif
09.06.2007 10:38 93 bg_row_hover.gif
16.10.2007 22:28 55 bg_row_hover_new.gif
13.03.2007 20:18 179 bg_spacerow.gif
08.06.2007 01:33 1.069 bg_th.gif
07.06.2007 01:49 218 bg_topnav.gif
06.08.2007 12:16 4.580 birthdays.png
07.06.2007 20:56 843 cat_block.gif
06.08.2007 11:32 21.643 copyright.png
01.11.2007 21:43 195 icon_maximize.gif
01.11.2007 21:43 188 icon_minimize.gif
17.08.2007 11:49 492 index.htm
08.06.2007 01:35 3.476 little_box.png
06.08.2007 12:23 3.907 login.png
08.06.2007 01:35 3.434 menu_sep.png
03.02.2007 21:30 2.995 no_avatar.gif
02.02.2007 23:00 7.151 online.png
07.06.2007 20:38 90 shadow_left.gif
07.06.2007 20:38 90 shadow_right.gif
02.04.2007 00:46 43 spacer.gif
06.08.2007 12:16 4.918 stats.png
17.08.2007 12:03 859 subforum_read.gif
16.10.2007 22:29 270 subforum_unread.gif
07.06.2007 01:19 102 tbl_f_c.gif
07.06.2007 01:19 183 tbl_f_l.gif
07.06.2007 01:19 182 tbl_f_r.gif
08.06.2007 01:11 177 tbl_h_c.gif
08.06.2007 01:11 492 tbl_h_l.gif
08.06.2007 01:12 505 tbl_h_r.gif
16.10.2007 20:47 2.915 top_header.png
49 Datei(en) 67.941 Bytes
Anzahl der angezeigten Dateien:
291 Datei(en) 1.693.519 Bytes
29 Verzeichnis(se), 1.172.631.552 Bytes frei
ThePhoenix
Ah, I see, so it won't show up becuase before I install the portal style I need the matching phpbb3 style ?
In that case do you have a link to the full style for phpBB3 ?
Hi Phoenix
If you download any Style from Board3-styles.de you can see at the end of each site (where you can download the style) the following requirements:
e.g. for Black Pearl:
Then, you can follow the instructions in the *.xml since you have all the files you need
EDIT:
Black Pearl: http://demo.phpbb3styles.net/Black+Pearl
AcidTech Tiger: http://demo.phpbb3styles.net/AcidTech+Tiger
This means, that you need to install the Style as first, and after then copy the content from Board3-styles into this Directory.Board3 Portal 1.0.2 & Black Pearl 1.4.5
EDIT:
ThePhoenix
Bingo, thanks for that, I'll get it downloaded and sorted ASAP
Genius
Don't suppose you know how to get my site to deault to portal.php instead of index.php ?
AT the moment if you go to http://phoenixgaminguk.com it goes to index.php, I want it to go to portal.php.
Genius
Reason: please dont make doublepostings
knowledge/kb_show.php?id=8
btw. if I click on your link, i correctly forwarded to you Portal and not to the board index...
ThePhoenix
Hmm, well ain't that a sod, it was not doing that earlier. Just tried it myself and your right. Must have been cached or sumin.
Thanks for your help guys.
