Your Portal Version: 1.0.2
Boardlink: http://localhost
nothing
edited .css files
I try to install the board3 portal, for now everything is correct, but in the current styles in this template, and the prosilver template, did you see that just the menu blocks and user menu blocks are diferent???? I wanna help to take these two blocks and fix with all others blocks like boardstyle or clock blocks....... can you help me???? I'm prosilver style, with colorize it, just another color......
PS i'll test everything and after i'll post the portuguese brazil translated files!
thanks
blocks with other colors
Re: blocks with other colors
Maybe you can use a subsilver2 based Template. These Templates have uniform Blocks on the left/right side and the center.
The other way to have this look in the style you use, is to edit the styles/*your_style*/theme/portal.css
japagun
- phpBB.com User: japagun
this is the problem, because with .css files i have a little difficult..
just to solve my issue, the left and right blocks i want "if you can" i want all like Statistics and other blocks like Board style or Birthdays without colors inside the blocks.... just the menu and the user menu blocks are with colors inside.... if i delete the portal.css files the background color will be delete to:?????
japagun
up.....anybody??
japagun
anybody give some light here......plase.
Hi there,
All you need to do is to change all occurrences of these two colors with your expected colors...
#DDE9F0 (found in .portal-panel)
#6ACEFF (found multiple times in .portal-navigation)
Examining your attached screen shot, I guess you need to change both colors to #E7EDED or something similar? Just give it a try.
Simply open the portal.css in any good programmer's/text editor, search for #DDE9F0 and #6ACEFF and replace both values with #E7EDED. Save portal.css and upload it to styles\your_prosilver\theme\ and refresh the theme cache. That's all.
Ricoh Digital and Film Cameras
http://www.ricohforum.com/
japagun
I`ll try and let you know if works...... thanks for now.odklizec wrote:Hi there,
