Your Portal Version: 1.0.2RC3
Boardlink: http://www.smivers.com/forum
Installed the board and the database installed correctly no errors
Re done all of the files and checked them all and re uploaded.
Basically my forum is coming up blank?
I have done everything I can think of, it will not let me go into the admin either.
If anyone could have a look for me, I will give temporary login details for the ftp.
Need it sorted asap.
Many Thanks
Blank page, I dont get it?
Re: Blank page, I dont get it?
Already read this? knowledge/kb_show.php?id=3
I guess you've build in an error during the file edits. It must be a basic core file, like the functions.php or common.php
Check it again - maybe replace the files by the original ones, one by one, to sort out which file is affected.
I have replaced them all with the original files and still not luck.
Would you be so kind as to login and have a look for me if i pm you details?
Many Thanks
Many Thanks
Do you have more mods installed, than just Board3 Portal? phpBB 3.0.4?
Yes, PM me the details.
Kevin I have sent you a pm with the details
Many Thanks
Many Thanks
I have sent, it says sent, but its going straight into my outbox? Any idea why Kevin?
Everything fine, received both of the PMs.bryntwr wrote:I have sent, it says sent, but its going straight into my outbox? Any idea why Kevin?
Okay, maybe i got it fixed. But your server seems to be overloaded right now:
No blank page anymore.http://www.smivers.com/forum/index.php wrote:General Error
SQL ERROR [ mysql4 ]
Too many connections [1040]
As i wrote before - this was the solution:
You had line breaks after the ?> in the functions.php and constants.php.Kevin wrote:Already read this? knowledge/kb_show.php?id=3
So you cant have checked the files properly. Next time please read all hints carefully and try them yourself.
Took another look, your server is barely back online. After manually purging the forum cache (which takes hours) your forum is back.
Additionally you forgot to upload the portal.css, i've done it now, but you have to recompile / refresh the template in the ACP to get it in effect.
Thank you, I am currently in the process of moving host, I have not had the time.
I did check them files and change them and it did not work so I changed them back
Thank you ver much for this, it is much appreciated.
Hi, I'm having the exact same problem here...
i've check all the spaces and blank lines, but still can't get it up and running...
Can you check it out please?
