Boardlink: http://www.catchfencephotos.net/portal.php
Not upgraded
Upgraded on my test system to PHPBB3 V3.0.1
Hi all,
I have been a bit slack and haven't upgraded either the versions of PHPBB3 (currently V3.0.0) or Board3 Portal (currently V0.2.1) since the final work I did in March last year. I have now started the process of testing the upgrades on my offline board, but this hasn't worked as required. Firstly I have upgraded my phpbb3 install to 3.0.1, but this broke the portal. Before I proceed and get myself in a big mess, I would like to work up an upgrade plan that will ensure that all components work correctly.
Should I
- Upgrade the Portal first to the latest version, then upgrade phpbb3 to V3.0.1 then the subsequent upgrades to the latest version
- Upgrade the board first then the portal
- Uninstall the portal, upgrade the board and then re-install the latest version of the portal
- something else
Cheers[/i]
