Hi Gents,
I'm really pleased with the speed and ease I've been able to put a portal up for our club. There are a couple of little glitches which I'm struggling with.
The portal automatically adjusts the width to suit the IE window size but the left and right columns are tight up to the edges. Is there a quick and simple way to add some padding?
No left margin
