Boardlink: http://infomaser.com
search all topic to find out about my problem
upload file
anybody can help me.. i dont understand about file copy.. did i need to upload file to any location
for example
File Copy
1-Copy: root/portal.php
To: portal.php
2-Copy: root/adm/mods/board3_portal_check_version.php
To: adm/mods/board3_portal_check_version.php
3-Copy: root/includes/acp/acp_portal.php
To: includes/acp/acp_portal.php
4-Copy: root/includes/acp/info/acp_portal.php
To: includes/acp/info/acp_portal.php
its that mean i should upload that all file?
i really want to use board3portal.. any tutorial about that here..pls help me
file copy
thomas.d
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: file copy
Yes maser,maser wrote:... anybody can help me.. i dont understand about file copy.. did i need to upload file to any location
for example
File Copy
To: portal.php
"file copy" means, that you have to copy the files from your PC to your server.
In order to get the board3 portal running, you got to upload the portal files and to edit and upload certain phpBB3-files.
After that run the installer.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
Spirit
Re: file copy
But don't make most common newbie copy mistake with copy-ing/replacing whole directory/folder. Copy just files from directory not directory itself, otherwise you will deleted previous dir content. Files from "adm" should be placed to "adm" on your server, but don't replace whole "adm" - just files in it.
