What Knowledge Base Are you Using?
Whatever... šŸ˜‰
airsoftpacific
Post by airsoftpacific »
What Knowledge Base are you guys using here on Board3.de?
Is it this one?
http://www.phpbb.com/community/viewtopi ... 0&t=589907
Seems to be a lot of bugs being posted. How is it working for you?
the.ronin
Re: What Knowledge Base Are you Using?
Post by the.ronin »
I’d be willing to bet that it is if anything based on the ā€œAdd Articleā€ bar at the bottom.
airsoftpacific
Yeah, it definitely looks like that one. The thread mentions so many bugs, I'd be worried to use it on a production site.
the.ronin
Post by the.ronin »
When I installed it, it worked out pretty smoothly. I just didn’t like the ā€œclassicā€ view when you listed out all the articles. I also wanted it to display the most recent article in its main page as well as in the portal. By the time I was done with it, I realized I could accomplish the same thing just by feeding a premissioned forum into the portal news block. That was the end of that mod.
Return to ā€œSmall talkā€
