Soul city style - problem with install.
delias
phpBB.com User: delias
Post by delias »
I have a problem with this wonderful portal, because I use a different style.
Please, help me.
In overall_header.html in line
i must add after this line <!-- ENDIF -->
but in my style overall_header.html has different code:
<head>
{META}
	phpBB style name: soul_city
	Based on style:   soul_city (this is the default phpBB3 style)
	Modified by:
// <![CDATA[
	var on_page = '{ON_PAGE}';
	var per_page = '{PER_PAGE}';
	<!-- IF S_USER_PM_POPUP -->
		if ({S_NEW_PM})
			var url = '{UA_POPUP_PM}';
	* Find a member
	function find_username(url)
		return false;
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
<!--[if lt IE 7]>
<link href="{T_THEME_PATH}/fix_ie6.css" rel="stylesheet" type="text/css" media="screen, projection" />
<![endif]-->
</head>
<div id="wrap">
	<div id="page-header">
		<div class="headerbar">
			<div class="inner">
			<div id="site-description">
				<h1>{SITENAME}</h1>
				<p>{SITE_DESCRIPTION}</p>
			<ul>
					<li><a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a></li>
					<!-- IF S_DISPLAY_PM --><li><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></li><!-- ENDIF -->
					<li><a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></li>
					<li><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a></li>
				<li><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">&nbsp;&nbsp;{L_FAQ}&nbsp;&nbsp;</a></li>
				<!-- IF not S_IS_BOT -->
					<!-- IF S_DISPLAY_MEMBERLIST --><li><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
					<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
					<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li>
			<div id="search-box">
				<fieldset>
					<input name="keywords" id="keywords" type="text" maxlength="128" title="{L_SEARCH_KEYWORDS}" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" />
					<input class="icon-apply" title="{L_SEARCH}" value="" type="submit" />
					<a href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}"><img src="{T_THEME_PATH}/images/search+.gif" alt="{L_SEARCH_ADV}" /></a> {S_SEARCH_HIDDEN_FIELDS}
				</fieldset>
				</form>
			<div class="inner">
	<div id="page-body">
if you know where I can add <!-- ENDIF --> , please, say me.
I trying many variants but after install always have a critical error.
Thank you[/i]
Re: Soul city style - problem with install.
Try this:
    <head>
    {META}
       Modified by:
    // <![CDATA[
          if ({S_NEW_PM})
       <!-- ENDIF -->
       * Find a member
          return false;
    </script>
    <!-- IF S_CONTENT_DIRECTION eq 'rtl' -->
    <!-- ENDIF -->
    <!--[if lt IE 7]>
    <![endif]-->
    </head>
    <div id="wrap">
             <div class="inner">
                <h1>{SITENAME}</h1>
             <ul>
                   <!-- ENDIF -->
                <!-- ENDIF -->
                <!-- ENDIF -->
                <fieldset>
                </fieldset>
                </form>
          <!-- ENDIF -->
<!-- IF not $S_IN_PORTAL or not S_DISPLAY_MAINMENU -->
          <div class="navbar">
             <div class="inner">
                <li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<!-- ENDIF -->
       <a name="start_here"></a>
           <!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) -->
             <span class="corners-bottom"><span></span></span></div>
          <!-- ENDIF -->
Is this style named "Soul City"?
delias
Post by delias »
Kevin wrote:Is this style named "Soul City"?
yes it is.
okey, thank you. when I try to install again, I inform you.
Thank you!
