User Blog Mod Block
Kharon
Re: User Blog Mod Block
thanks, it is working
Amo
- phpBB.com User: Amo
I;'m going to try this tomorrow, really appreciate this dan. id do it noww but im a tad too drunk lol >.<
Anotheridiot
- phpBB.com User: Anotheridiot
User Blog Mod has been updated to 1.0.10 last week.
I can confirm that this block works with the following versions of User Blog Mod
1.0.8 - Working 100%
1.0.9 - Working(Unconfirmed Bug - minor style issues if installed as first version)
1.0.10 - Working 100%
What I'd like to do with this next is take the 'Total Blog Entries' from the bottom of the index.php and add it to the Statistics block.
-Dan
_______________________________________
Lifes not fair... but the Root Password Helps !
FLATTOP
Thanks alot for the code guys, it works great! I changed the output from 5 to 3 so it doesn't take up too much space on my portal.
zappa84
Kevin wrote:To use the advantages of new features for additional blocks (easier updating portals with additional blocks) and the template variables, i would suggest to build the code of Dan up like this:
- open root/portal/block/additional_blocks.php
find:add after:Code: Select all
if (!defined('IN_PORTAL')) { exit; }Code: Select all
include($phpbb_root_path . 'portal/block/blog_block.'.$phpEx);- Create a new File, called blog_block.php, contend:
upload this file to root/portal/block/Code: Select all
<?php if (!defined('IN_PHPBB')) { exit; } if (!defined('IN_PORTAL')) { exit; } // Output Blog Entries $blog_limit = 5; $user->add_lang(array('mods/blog/common', 'mods/blog/view')); include($phpbb_root_path . 'blog/functions.' . $phpEx); $blog_data = new blog_data(); $recent_blog_ids = $blog_data->get_blog_data('recent', 0, array('limit' => $blog_limit)); $blog_data->get_user_data(false, true); update_edit_delete(); if ($recent_blog_ids !== false) { foreach ($recent_blog_ids as $id) { $template->assign_block_vars('recent_blogs', array_merge($blog_data->handle_user_data(blog_data::$blog[$id]['user_id']), $blog_data->handle_blog_data($id, $config['user_blog_text_limit']))); } } ?>- Create a new File, called blog_block.html, contend:
upload this file to root/styles/prosilver/portal/block/Code: Select all
{$C_BLOCK_H_L}<dl><dt>{L_RECENT_BLOGS}</dt></dl>{$C_BLOCK_H_R} <div class="panel" style="margin-bottom: 0px"> <div class="inner"><span class="portal-corners-top-inner"></span> <!-- BEGIN recent_blogs --> <div class="post bg1<!-- IF recent_blogs.S_REPORTED or recent_blogs.S_UNAPPROVED --> reported<!-- ENDIF --><!-- IF recent_blogs.S_DELETED --> deleted<!-- ENDIF -->" <!-- IF recent_blogs.POST_COLOR and not recent_blogs.S_REPORTED and not recent_blogs.S_UNAPPROVED and not recent_blogs.S_DELETED -->style="background-color: {recent_blogs.POST_COLOR}"<!-- ENDIF -->> <div class="inner"><span class="corners-top"><span></span></span> <div class="postbody" style="width: 100%;"> <!-- IF recent_blogs.S_UNAPPROVED or recent_blogs.S_REPORTED --> <p class="rules"> <!-- IF recent_blogs.S_UNAPPROVED -->{UNAPPROVED_IMG} <a href="{recent_blogs.U_APPROVE}"><strong>{L_UNAPPROVED}</strong></a><!-- ENDIF --> <!-- IF recent_blogs.S_REPORTED -->{REPORTED_IMG} <a href="{recent_blogs.U_REPORT}"><strong>{L_REPORTED_SHORT}</strong></a><!-- ENDIF --> </p> <!-- ENDIF --> <dl> <dt> <strong><!-- IF recent_blogs.S_HAS_POLL --><img src="{T_THEME_PATH}/images/blog/icon_poll.gif" style="float: right;" alt="" /> <!-- ENDIF --><a href="{recent_blogs.U_VIEW}">{recent_blogs.TITLE}</a></strong> {L_POST_BY_AUTHOR} <strong>{recent_blogs.USER_FULL}</strong> {L_POSTED_ON_DATE} {recent_blogs.DATE} <br /> <div class="content" style="width: 95%; padding: 4px;">{recent_blogs.MESSAGE}</div> <!-- IF recent_blogs.S_HAS_ATTACHMENTS --> <dl class="attachbox"> <dt>{L_ATTACHMENTS}</dt> </dl> <!-- ENDIF --> <br clear="all" /> <div> <span class="num_replies">{recent_blogs.REPLIES}</span> {recent_blogs.VIEWS} </div> </dt> </dl> </div><span class="corners-bottom"><span></span></span> </div> </div> <!-- END recent_blogs --> <span class="portal-corners-bottom-inner"></span></div> </div> {$C_BLOCK_F_L}{$C_BLOCK_F_R}- open /styles/prosilver/template/portal/block/additional_blocks_center.html
<!-- additional_blocks //-->Code: Select all
<!-- INCLUDE portal/block/blog_block.html -->
Not tested, but that should be it. Dont forget to purge the cache afterwards.
This is just great! but could you help me out to find the right code for subsilver2? please i really would like to set it up in the portal...
Parkstee
- phpBB.com User: Parkstee
Hi just tried this on my site and get the following error:
How can I fix it please
[phpBB Debug] PHP Notice: in file /blog/includes/blog_data.php on line 440: Undefined index: MAX_OPTION_SELECT
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4247: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3503)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4249: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3503)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4250: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3503)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4251: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3503)-
vonhazey
- phpBB.com User: vonhazey
yogiiskandar
- phpBB.com User: yogiiskandar
any edit for subsilver please
diesusi
- phpBB.de User: diesusi
Hello!
Sorry, my english is really bad.
I'm looking for the a simular block.
I'd like to get the recent comments on a block on the Portal, but I don't know how to.
Would anybody help me please?
Thanks a lot!
Thanks a lot!
Antartico
Hello everyone,
As I wrote in my previous post, I'm using board3 + the blog mod.
Talking about the blog mod:
- How can I put a post in the embed code of youtube?
- There is a html editor for the posts?
- Is possible to show in the "blog mod block" a preview of the post? To let you know, as a blogger's function <--more-->
