Aero Blue theme help
fac7orx
Post by fac7orx »
Your Portal Version: 1.0.2
Your phpBB Type: phpBB 3.02
Switched it with subsilver 2 overall_header files. Tried looking in the ACP.
___________
Usually Subsilver 2 and Aero blue are pretty similiar. However, when I looked at the Aero Blue header and compared it to the Subsilver header it is completely different for some reason.
Here are the forums after I switched the Overall header files:
http://www.pixelsmashers.com/prac/
Is that suppose to be like that? I think it is a bit off.
Here is the header file for Aero Blue:
http://files.filefront.com/overall+head ... einfo.html
Also, is there anyway to edit this mod aside from going into the php or html documents? I tried looking around in the acp and I could not find anything :(.
dragz
Re: Aero Blue theme help
Post by dragz »
Go to board3-styles.de, U will be able to find the theme for the portal there, ;)
fac7orx
Post by fac7orx »
dragz wrote:Go to board3-styles.de, U will be able to find the theme for the portal there, ;)
Thank you so much! That helps quite a bit :D.
